Hello all,
I have a project with different phases in which I have linked some rvt models. I want to export a dwg having all the elements in grey colour.
How can I do it?
Thank you in advance!
Have you tried selecting everything and then right click > override graphics in view > by element and then change colours and patterns as required.
You can modify the export settings for CAD exports and set the colours for the layers. To do this, go to File - Export - Options - Modify DWG Export settings. Set the colours to grey.
in your export, change your Export Layer Options:
Howard Munsell
ok I will try it.
And if I want to export exaclty the colours that I have in the view in Revit, what I should do ?
Thank you !
edit the export table to reflect what colors your using in Reivt.
Howard Munsell
