Linked DWG
Linked DWG
mylesXGYYA
Linked DWG
mylesXGYYA
Hi all,
Having issues with a Linked DWG survey.
In my Revit view I have text and notes turned off in the DWG. Most print turned off however some text from the DWG still print even when turned off. the main issue is they print upside down.
I don't particularly want  modify the CAD survey.
Also when I print to PDF the page prints upside down to all the other pages.
Any ideas on how to rectify this?
Myles
SteveKStafford
You'll need to determine if all the text is assigned to a unique layer(s) so you can turn them off. It's also possible that some text is part of blocks in which case you'll need to ask the people who provided the DWG to alter how they set the drawing up so it works with your model better.
Steve Stafford
handjonathan
Hi @mylesXGYYA
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
damion_a_patterson_ctr
Community Visitor
Community Visitor
I feel like this place just scam me out of my money and time. I have communicated with you guys so much and yet to do a simple thing as just to product my certificate. i have told all my friends to discontinue.
