Linked Cad Drawing bellow issue
I have linked a Cad Drawing on a plan.
The problem is once I draw a wall I don't see the linked cad bellow where I have the other cad elements drawn (windows, doors..) as a reference..
How you deal with this?
SamBerk
i tuglle off the thin lines option
As long as it is linked and not inserted, you can change the Draw Layer in the Properties or Options Bar from Background to Foreground when you select the DWG.
Alan.johnson1970
You could set the Graphic Display to Wireframe, you will then be able to see the doors/windows below
AJ.
@Anonymous
I attach a screenshot. Once I selected the linked cad I cannot see that option in the properties tab..
SamBerk
you don't need to select the cad file ,wen nothing is selected then select this option
Ah, you didn't link in "Current View Only"...
The wireframe suggestion is your only option then.
