Link visibility issue?
Message 1 of 9
Hey, im currently working on a model with structure revit file linked in as Overlay.
Filter has been added so that structural walls and colums display in orange color, with 35% transparency.
The issue is that in some places, like one shown on picture, revit structure link is actually occluded by walls in my model, whereas I would like it to be over/in front of my model and with transparency.1.PNG
Replies (8)
Message 2 of 9
would really appreciate help guys
Message 3 of 9
Karol_Piroska
they way I do it is to change lineweights - heavier lines for linked model and very thin for my elements. Then you can see clearly all elements, even if they are in the same place.
Message 4 of 9
Another option is to create a filter that shows structural walls in a different colour and switch off the cut patterns.  Keep the patterns in the arch walls so that you can see where they coincide.
Message 5 of 9
The thing is - this filter already exists and its on. The thing is that on this level it seems to be occluded by other walls, which is weird for me - view range is the same on every view - and on other plan views the cut works just fine showing overlapping walls in architecture and in structure.
On first photo i show the affected view - where arch walls occlude structure walls - you can see occluded walls more clearly when its selected in revit - thus showing them in 'ghosted' way
On the second photo we see correctly working view of a floor above - structure and architecture walls overlapping correctly.
Message 6 of 9
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thanks for your post! Would you be able to upload the model so we can take a look on our end? Thanks!
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Message 7 of 9
Hey, thanks!
I'll need your email to add you to A360 where I've uploaded these files
Message 8 of 9
andrea.kikuchi
Autodesk Support
Autodesk Support
Thank you for the model. I'm taking a look at the walls now. They appear to be the same so I'm not sure why the views are different. I will let you know what my investigation finds!
Andrea K
Message 9 of 9
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @Anonymous,
There are a lot of overlapping walls in this area, I would look at how the walls are modeled and the property settings for each one. Redrawing some of them in the affected view showed the link as expected.
Andrea K
