Link Survey CAD keeping Line Patterns
stingers80-cgarchitect
Is there a good workaround to Link a Survey DWG into Revit View and keep its Original Line patterns? Survey files have a lot of Line patterns that use Letters in them, impossible to replicate in Revit.
The only workaround I have is to print a PDF of the DWG and then import it in Autocad again so that everything is exploded into shapes. Then I will Link this DWG in Revit.
Is there a better way?
syman2000
You can try exploding the linetype in AutoCAD by using this lisp from the link below.
https://www.cadforum.cz/en/how-to-explode-linetypes-to-dashes-tip6804
