Link Revit is grayed out
Message 1 of 29
I have a 2011 Revit model open that contains one linked revit file that was present when I get the model.
I need to add another linked Revit file but the Insert>Link Revit selection if not available to me (greyed out).
Why is this like this and how do I get revit linking to turn on again?
This file is in Revit Server.
Replies (28)
Message 21 of 29
My dude!! That did it!!! Thanks!!
Message 22 of 29
aakhkend
Observer
Observer
Thank you so much
Message 23 of 29
ErnieMack7484
Totally solved the problem.
Thank you
Message 24 of 29
RobDraw
Lesson learned?
In Revit, when you want to insert something, you need to be in an appropriate view.
Rob
Message 25 of 29
martijn_pater
However it might not always be appropriate to insert something, just to be clear on that. Seems obvious that you shouldn't insert 3d content on a sheet though, so you need to be in an (active) model view... just my three cents, which might have been one too many...
FWIW I didn't see it specified in the manual...
Message 26 of 29
Thank you! This helped
Message 27 of 29
douglas.robertsonS8BU9
Andrew, you are a Genius. I am a long time Revit user and sometimes the simplest solution does readily present itself. You save me heaps of angst. Thanks Doug Robertson
Message 28 of 29
ChrisRWKE5
The reason is that you cannot link another model while you are on a sheet, which is why it worked when you were in the 3D view.
Message 29 of 29
thiswillgotorobert
This is a new reply to an old reply to an old topic, But it worked!
Thanks for the Tip!
