Link Project Pattern File and Title Block Pattern File
6 REPLIES 6
dm0144
324 Views, 6 Replies
I want to create a material legend built into the title block.
The issue is that I don't find the exact patterns inside the title block family.
How can I link, import, or find the exact patterns from the project with the ones inside the family?
6 REPLIES 6
in reply to: dm0144
Use Transfer Project Standards to transfer Materials between open Projects.
in reply to: dm0144
A better approach might be save all of your most commonly used Materials to your Favorites Folder - or to a custom ADSKLIB.
dm0144
in reply to: barthbradley
@barthbradley and do you know where is the file location of the pattern file for the project as well as the title block family?
in reply to: dm0144
The Fill Patterns?  Fill Patterns are defined in the Revit Project.  Fill Patterns can also be transferred between Project via Transfer Project Standards.
brykerAEEEK
in reply to: dm0144
this is the path to revit.pat on my laptop.
C:\Program Files\Autodesk\Revit 2023\Data
in reply to: brykerAEEEK
Interesting. Good contribution, @brykerAEEEK.  I've never pulled from that file before (no reason to), but it's doable.
