link/import Autocad files not useful
Dear Sirs
Please provide advice on how to get to link autocad files as the example attached with a useful result.
regards
Adolfo Martínez
Sahay_R
Your DWG has units set in MM. When I linked it into my RVT, I got the same result because my RVT had units in feet and inches.
Make sure that units in both the DWG and RVT match before linking.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
I haven't had the chance to open you file, but when you link it, slow down a little bit and look at all the options in the dialog. I would check the unit first, then choose center to center.
As you indicated, the .DWG was drawn in meters therefor the given result. Thank you for your help
Sahay_R
Glad to have been able to help!
Rina Sahay
