Link IFC2x3 supported IFC solid model geometry entites?
klqa_test
klqa_test
What are IFC solid model geometry entities that are supported in Link IFC2x3, in Revit 2020?
I've tried few of these that are working such as IFCFACETEDVBREP. IFCEXTRUDEDAREASOLID and IFCREVOLVEDAREASOLID. But IFCSURFACECURVEAREASOLID does not work.
/zac
Rafal.Gaweda
Autodesk Support
Autodesk Support
klqa_test
Thanks for the info.
The document mentioned about SweptSolid, I thought IFCSurfaceCurveSweptAreaSolid should works with Link IFC.
However, it is not visible in Link IFC.
/zac
mikako_harada
Hi Klqa,
Looks like this explains the reason for the failure:
https://forums.autodesk.com/t5/revit-architecture-forum/problem-linking-ifc-extrusions-into-revit-20...
I logged an enhancement wish:
CF-4974:  IFC geometry fails to link and display due to the small entity
Mikako Harada
Developer Technical Services
