Lineweights in steel Framing sections
Caed9
Caed9
Hi, I'm doing some Structural Framing , but in the sections when I activate the lineweights the steel frame ends up really thick and the lines end up covering the whole Steel profile. I tried editing the lineweights and the lines started to thin, but there where some thick dots in on the corners.
How do you do in this cases, in order to create documentation, do you leave those thick lines or should I just lower down the lineweight more, I lowered them to .0500mm but the steel profile still remained represented with thick lines. The  joist remained really thick as well, I guess I will have to keep lowering down the linewight. But how do I remove the the thick dots.
By chance do you think that once it is printed it fixes and the details are properly shown?
I lowered to the least which is .025 and the thick dots are still there and the steel beam is not properly detailed.
Analytical Nodes?
...can you select it? if so, right-click and hide catagory
_Vijay
Or you can hide from Visibility graphics as in below image.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
_Vijay
Vijayakumar
Head of BIM
