Lineweight in Window Family
PhilvK
Advisor Advisor
Message 1 of 15
PhilvK
I created a simple window family, used an extrusion for the glass, and set the extrusion material to 'glass'. I want to reduce the glass extrusion lineweight, but changing the 'cut' thickness of 'Glass' in Object Styles has no effect.  What am I doing incorrectly?Line Weight.JPG
Replies (14)
Message 2 of 15
RDAOU
Did u set the extrusion to glass subcategory?
Select it and on the properties palette pick glass
Message 3 of 15
PhilvK
Yes, already did that.
Message 4 of 15
RDAOU
Maybe u r in Thin line mode? Type TL to toggle on off
Also apply preview cut (in the task bar at the bottom of the plan view...
Message 5 of 15
PhilvK
Nope, not in Thin Line mode, and Preview shows same thing.
Message 6 of 15
RDAOU
Is view Wireframe ??? Did you Load family into project and check?
Sorry if yoy already posted images,,, I'm reading/replying via email, images don't display
Message 7 of 15
PhilvK
I can't change it in the project either
Message 8 of 15
RDAOU
Can u share that family?!
Message 9 of 15
PhilvK
Sure, thanks for looking at it
Message 10 of 15
RDAOU
@PhilvK
You assigned material as Glass, not the subcategory...Scroll a little bit more downwards and select from the drop down Glass Subcategory (See GiF below)
Message 11 of 15
PhilvK
Dang...thank you!
Message 12 of 15
PhilvK
Sorry to bother, but the changes don;t seem to carry over into the project??
Message 13 of 15
RDAOU
What changes? You need to set line weights in project ...
Message 14 of 15
PhilvK
I changed Windows > Glass cut lines to '2' in Object Styles - no effect.
Message 15 of 15
PhilvK
I deleted the family and replaced it. Now it's working. Thanks again.
