Lineweight defined in Title Block family doesn't appear in model file
DaviMeloPereira
Message 1 of 13
DaviMeloPereira
Hei guys.
I'm creating a new Title Block Family, but the lineweights defined inside Title Block Family doesn't work on the model file. I already checked the Line Style Settings and Lineweight Settings in both files (rfa and rvt) and they are the same.
I attached the files in case if you wantto see them.
On left is rvt file and on right is rfa
Replies (12)
Message 2 of 13
In project, VG > Annotation tab > Titleblock > expand to see
subcategories. That is where you should look at, not Project line styles.
Message 3 of 13
GustavoUbriaco
Hi, you Family it's ok, is the linweight configuration in your project, check this.
Gustavo Ubriaco Contreras
Message 4 of 13
DaviMeloPereira
Thank you for your help, but on VG there aren't any changes on this category
Message 5 of 13
DaviMeloPereira
Thak you for your help.
It is weird, because on my PC, my project it's defined with 1.2, equal I defined on family
Project
Family:
Message 6 of 13
GustavoUbriaco
So strange, is your revit updated?
Message 7 of 13
DaviMeloPereira
I'm using REVIT 2020
Message 8 of 13
GustavoUbriaco
 I got it check this all in your project OBJECT STYLES is in 1
Message 9 of 13
DaviMeloPereira
I'm so gratefull for this.
Inside Object Styles on VG. Sometime I forget it. rsrsrsrs
Message 10 of 13
Hooray for @GustavoUbriaco!  Even with all these merit badges, I couldn't figure it out.
I'm going for the Autodesk Certified Professional Merit Badge next.  Wish me luck. 😉
Message 11 of 13
GustavoUbriaco
Let's collect all them buddy, you're a master with or without badges 🥇
Message 12 of 13
GustavoUbriaco
Com muito gosto amigo!
Message 13 of 13
fmartinezY7FW6
The line thickness of a title block in a Revit VRV project is managed by the model line thicknesses at 1:1 scale. Even though they are annotation lines, they are not assigned thicknesses based on the annotation lines tab. They are counted as model lines. Try setting this 1:1 tab to the desired thicknesses. For example, I set this tab to the same thickness as the annotation line thicknesses tab.
