Lines or objects not showing up until I place them
mcenWREPF
mcenWREPF
Whenever I try to draw anything or move anything the lines or the whole object itself doesn't show up until I finished drawing the line or moving the object.
I already tried uninstalling and reinstalling the product but it still remains the same. I also have my graphics drivers up to date. I don't know what's causing this problem to occur and I can't find anyone with the same issue as mine, it's really frustrating šŸ˜ž.
(view in My Videos)
Ryan_GormanKT36T
is this a problem in a specific view/project or everywhere?
This content was generated by a human who can make mistakes. Please verify important information.
mcenWREPF
It happens everywhere no matter the project or the view
Pavankumar_H
Hello @mcenWREPF ,
Thanks for reaching out to us on Forum.
I would suggest you to turn off hardware acceleration in Autodesk Revit, follow these steps:
To turn off hardware acceleration in Autodesk Revit, follow these steps:
  1. Open Revit.
  1. Click the File tab in the upper-left corner.
  1. Select Options from the dropdown menu.
  1. In the Options dialog box, navigate to the Hardware tab on the left-hand side.
  1. Under the Hardware section, you will see a checkbox labeled Use Hardware Acceleration. Uncheck this box to turn off hardware acceleration.
  1. Click OK to apply the changes and close the Options dialog box
Pease use Accept Solution so that others may find this useful in the future.
If you still have the issue, please let us know.
Thank you!
mari.shimode
Hi @mcenWREPF, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
mari.shimode
Hi @mcenWREPF, since @Pavankumar_H's reply is useful to the community, I have marked it as an accepted solution so others who have the same question can refer to it.
If you're still having the issue or have any other questions related to what you originally asked, please create a new topic with a link to this post included so the community can follow the conversation easily.
Mari Shimode
