Lines not printing as set
GastonBC
Message 1 of 8
GastonBC
Hi, my problem is that I'm trying to print a sheet but the lines are coming out too thick.
I have set the line weights to 0.05 in Line Weights and made sure the object styles match my needs. In screen I can see it the way I want it but the moment I print it to PDF it comes out thick
I'm using Adobe PDF as printer and Revit 2017 if that's helpful.
Replies (7)
Message 2 of 8
Are you sure Thin Lines is toggled off in order to see how the lines actually look?
Message 3 of 8
GastonBC
Yes, that's toggled off, I even tried to print it with thin lines On but they still come out thick
Message 4 of 8
Can you share the PDF and a screenshot of the Revit sheet with Thin lines OFF? Have you tried a different PDF printer?
Message 5 of 8
GastonBC
Sure thing.
I tried Microsoft PDF printer but didn't work + it bugs out (freezes) my printing options
Message 6 of 8
GastonBC
Alright after doing some research I found out the minimum line weight revit plots is 0.85mm. I don't understand why but I urgently need a solution or a workaround please.
Message 7 of 8
No way the minimum line weight when print out is 0.85 mm. That is fat.
0.075mm per https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Printing-lines-thinner-t...
Message 8 of 8
mairh_tsek
@GastonBC ,
Check if you have applied 'Cut line Styles' in the VG. (See attachment)
-Also if you have Overrided graphics by element/Category.
-Check also if a View Template is applied or filters.
