Lines in image show too thick.
abdurrashad187
abdurrashad187
Spider Glass Fitting Top View - Floor Plan - F2_FLOOR 2 FFL - Callout 1.jpgWhen i Export any 2d image from revit in image lines show too thick. but in 2d view its right no as thickness in image.
edwin.prakoso
How did you export the image? Did you capture it or use file>export>image?
Do you activate the thin lines option in Revit? It will make all lines look thin, but when you print or export the drawing, the thickness will follow the line weight settings.
Cheers,
Edwin Prakoso
abdurrashad187
I just reduce scale size my issue solved thank.
mari.shimode
Hi @abdurrashad187, it's great you could solve it yourself. I have marked your reply as an accepted solution so others who have the same issue can easily find it as a possible solution. Please visit us again.
Mari Shimode
