Lines bleed through plane in 3D view
- Mute
- Permalink
- Report
Hi! I'm having a problem where lines behind a plane bleed through if I'm on 3D. This shows even in exports. I think it happens in small scale drawings. This also happens even if the geometry is made in one whole extrusion.
Here are some examples, as you can see, on one image, the casework is made of one extrusion, but the shelf still bleeds through the side panel. On the other image, the sheet is placed on top of the beams, the sheet is 16mm, but as you can see, the beams still bleed through it. Anyone knows what's causing this?
