Line Width of Floor System
How do I change the line weight of a floor system in the section view?
The bottom line of the deck is too wide.
Look at attached photo, the part highlighted is what I am talking about.
samuelsanf
Best way is on Visibility/Graphics Overrides (keyboard shortcut VV), look for Floor Category and change the Override for Projection/Surface Line.
Or use Linework tool (LW) to change the representation of one line in particular.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
samuelsanf
Also, you can edit Graphics parameters of the material asigned to this floor on Manage tab, Settings panel, Material and look for the material on the deck.
