I have a generic model that I use in 2 different projects using the same view templates but the thing is 1 project, the generic model lineweight is showing as if its a 3 while the 2nd proj. its showing as 1.
I know its a setting somewhere.
any clues?
thanks,
Howard
Solved by aleksei.tkachenko. Go to Solution.
Solved by Sahay_R. Go to Solution.
Manage>>Additional Settings>>Line Styles
Take a good look and make sure that the linestyle you want has the right weight.
nope to both. Tried them both before posting.
actually, it was in the View Template - Model Display setting for Silhouettes. had it set to something and realized it should be set to <none>.
Thank you,
Howard
