hello everyone.
recently i'm working on a project which is going to construct with concrete .
when i add concrete walls between concrete column and beam revit shows line between them .
i joined them but still have that lines .
all of them have same material(concrete cast in place)
is it correct?
is it any way to tell revit dont show line between same materials?
When you make the concrete Walls , make them Structural not Architectural and the seam line will vanish.
I the wall is Architectural you can turn it into Structural as shown below:
And the seam will vanish...
Constantin Stroescu
hi Constantin
thanks a lot for your answer . i tried and it worked
but in my case this walls are not structural they are covered with concrete finishing (5cm) and they haven't structural core . the way u told is working fine but any other way not to change the wall to structural because its not and we are working on BIM software.
thanks
try now to uncheck Structural... See if the seam line kips hidden.....
Constantin Stroescu
