Line based family problem
spoonkim
Message 1 of 8
spoonkim
Hi
I want to draw a arrays of boxes as you see picture below. I created a line based family but as you see there's gap between the boxes. What did I do wrong here??
Replies (7)
Message 2 of 8
ralphdenhaan
See attachment, is that the way you want it?
I put an offset for the brick and it fills the Length.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 3 of 8
spoonkim
I choose "Last" for the array 'cause I assumed they would be the same thing. Can I choose "Last" for this kinds of array?
Message 4 of 8
The next step after you Array to 2nd, is to align/lock the 2nd to a Ref. Plane.  That Ref. Plane represents the spacing and is parametrically driven.  This parameter is needed in the formula that computes number of elements in Array.
Message 5 of 8
FWIW: You may want to have an Array that computes an end panel width when the overall Length is not equally divisible by the Arrayed panel width.  See attached.
Message 6 of 8
spoonkim
Thanks for your reply.
I aligned the edge of the boxes for the spacing instead of the ref plane but then I got a warning message as per image below. Can I align it to the each edges instead of the ref plane?? What would happen if I don't?
Message 7 of 8
 You're already seeing what could happen if you don't. The Array is breaking before your eyes.  Frankly, I would just follow Revit's advice.
Message 8 of 8
ralphdenhaan
Yes, I did use 2nd. See the attachment for the revised family with the filling end part as @barthbradley mentioned.
