Limit parameter potential values in family
BenoitE&A
BenoitE&A
Hey,
We have a family (Mech Fitting but does not matter).
We want the user to be able to choose only between 4 choices (text only, not int).
Is this possible?
I did not find out how using a formula.
Thx !
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
L.Maas
There are many different ways
Here an example.
Other method could be to make 4 different family types. Then the user only hs to select the proper type.
Louis
Please mention Revit version, especially when uploading Revit files.
BenoitE&A
Thanks.
It ends with modifying an Int for the user, which is not really great for simple users. But it'll do the job, provided that the 2 parameters are close in the Property pannel (which we'll settle).
I don't want to have multiple families/family types, always messy in code.
Thx anyway, we'll do the first solution.
Benoit FAVRE
BenoitE&A
Though... This is messy in code too : I need to work on the associated parameter (Choice in your example) instead of the one I'm interested in (Options) if I want to modify the value, which is bad.
No solution at all to use only 1 parameter, with Text values ?
Benoit FAVRE
Mike.FORM
Until Revit adds a "List" parameter type where you then put the items you want in the list into the formula field and they come up as a drop down in project/properties there is really no great way to do this other than what has been shown.
L.Maas
No, Revit has not something like a predefined list for a parameter (unfortunately) inside a family.
Not knowing what and how you are programming. Maybe you can leave the parameter empty, present the user a selection with your code and then push that choice into the parameter?
Another option might be to make use of a key schedule (inside a project).
With a key schedule you can present a user limited choices
But I expect this might cause issues too within your program.
Louis
