Light placement panel missing.
I'm placing lighting fixtures in a ceiling plan view.
There is no Placement panel in modify tab, how can I display it?
Alan.johnson1970
Without checking the actual family
The light fittings look different in the two images, looks like the second one is ceiling hosted.
Will only go in a ceiling, so no need for the placement options.
AJ.
I was watching a video tutorial , the second image was captured from the video.. and I have loaded the same family that mentioned in the video.. I don't know why there is a difference between the two light fixtures' icons in the type selector list.
Alan.johnson1970
can you upload the family file ?
AJ.
@Anonymous
I bet you loaded the family from Architecture folder and it is a ceiling based fixture. The one in the video is a face based fixture and it should be in MEP folder.
I've deleted the family and reloaded it from MEP folder, you are right ToanDN.
Thank you all !
@Anonymous
Please mark @Alan.johnson1970 reply as a solution.  He was giving the first correct answer.  Thanks!
