Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Light fixture can not work on the ceiling panel
mwang7DKXEF
mwang7DKXEF
I add a first level ceiling panel on the second floor. Why the light fixture can not work? I have to create a new first level of ceiling board, and then the light fixture can be stay. Thank you.
You cannot place a ceiling host family under a floor.  Use  a face based family in MEP folder, not Architectural folder, then you can host it under the floor.
mwang7DKXEF
You mean: I have to create a new ceiling board, and then light fixture can be stay, right? thank you
That is not what I meant but if you want to use the ceiling host light fixture family then yes you do need to create a ceiling below the floor.
mwang7DKXEF
Thank you so much. I do not understand this: Use  a face based family in MEP folder, not Architectural folder, then you can host it under the floor. Could you explain more or show some photos? Than you.
mwang7DKXEF
Thank you so much!😀
