Light Bleeding through Material.
KraiggC
Message 1 of 22
KraiggC
I have a light fixture, attached, and the light source is bleeding though the body and washing out the wall where the light connects to the wall. Anyone know what's causing this?
Replies (21)
Message 2 of 22
Renders beautifully for me.
What's the result at you end? Did you apply the correct materials to the lens and housing?
Message 3 of 22
KraiggC
The image in my original post is how it renders for me. Where the housing attached to the wall you can see a light halo. My Lens material is transparent and my housing material is opaque.
Message 4 of 22
Message 5 of 22
KraiggC
Well what the heck.. I'm rendering with VRay i wonder if that's one of the issues?
Message 6 of 22
Change your settings. Your background is set to "None" I'll bet. Use "Sky".
Message 7 of 22
You mean this?...
Message 8 of 22
That last one was "Realistic". This one is the same one, except Rendered via "Ray Trace"....Real Render.jpg
Message 9 of 22
Come back at me Kraig; I'm in the weeds with you on this one. What's the story?
Message 10 of 22
Can you make sure the VRay's retrace parameter under Light Cache dialog is checked?
Message 11 of 22
ToanDN wrote:
 ...VRay's retrace parameter under Light Cache dialog...
Where's that?
Message 12 of 22
VRay settings I supposed. Not Revit's.
Message 13 of 22
@ToanDN: I don't know who that last post was directed at, but I'm curious to know about the V-Ray setting you referenced; "Retrace Parameter". Where's that one located?
Message 14 of 22
Do you have Vray?
Message 15 of 22
@ToanDN wrote:
Do you have Vray?
Huh? Yes.
Message 16 of 22
...somewhere inside V-Ray "Settings" maybe?  (under the "Gear" icon)
Message 17 of 22
I will need to install vray again to find it.
Message 18 of 22
Darn you @ToanDN! You're my mentor. You're suppose to know this stuff! Now I'm left to wonder. What a pisser!
...edit: I'm editing this to change "D a m n" to "D a r n", thanks to these parochial  M.F.'s.
Message 19 of 22
Try toggle between Full Light and Adaptive Light maybe.  The one I mentioned earlier is a setting from VRay for Max hehe.
Message 20 of 22
You're Right!!! That is 3-D Max!
