Thank you for responding,
I understand that I can create parameters as needed, but the fact of the matter is that code compliance is a large part of what everyone using Revit does and it seems to be a relatively misrepresented segment within Revit. There are countless discussions on the web of how to produce life safety drawings using Revit. For example: how to visibly represent fire ratings, we can use detail lines and make a group and copy that group across all views of that floor, but than it has to be updated along with the walls and they dont talk to each other, or translate to our consultants when they link in an architectural model. Another way is to change the core material of the wall or use Filters, while both of these also work to a degree, the major issue is that they do not cross doors or windows. I was thinking that maybe a separate view type with separate finctionalty such as an area plan could/should be developed to address life safety views. Another example would be travel distances, there are two generally accepted work-arounds right now. one is using a railing family and the other is to create an adaptive component family, both options have their limitations and are not fully capapble of performing the intent of a travel distance line.
these are just a drop in the bucket on items that could be incoorporated involving code compliance and review tools, but based on the way you answered my question I feel like the answer is that Autodesk is not pursuing this topic to develop.
thank you,
