Licesing System Error 1
I Installed Revit in my computer and i wanted the student license, and i made the process step by step, but everytime i try to open revit it says "Licesing System Error 1". What do i do? Please help
L.Maas
I have something similar with Revit 2018.1 on one computer.
When starting Revit for the first time it gives this error and after clicking Ok it closes.
In my case the weird thing is that when i start Revit the second time it starts without the error message.
So only a small annoyance.
You also can look on THIS page of the Autodesk knowledge website to see if there is a solution for your issue.
Louis
Please mention Revit version, especially when uploading Revit files.
i already tried all of the suggestions and it still doesn´t work...
L.Maas
What do you mean tried all of the suggestions? From that page or also from other sources?
Might help if you mention what you already tried.
In general other things you can try.
-Check for updates (windows, Revit, .Net).
-Repair or Reinstall the Visual C++ Redistributable files (they can be found HERE).
-Do a clean reinstall of Revit.
Louis
I already reinstalled Revit, i already made all the updates on my computer, i already tried to run as a administrator... and it still makes the error... i don´t know why...
