Library Project Browser Organization
sbrandsrud
sbrandsrud
I've been tasked with setting up a standard Revit detail library for our office. I'm currently in the process of putting together a standard naming convention for new details that will be added to this detail library. My question is how do I remove the leading text "Drafting view" in the the project browser? (See images below). Does anyone know if this is possible?
RDAOU
@sbrandsrud
Try a different project browser sorting/filtering method.
sbrandsrud
@RDAOU
Do you know a tutorial off hand or have a suggestion for a proper detail view sorting/filtering method for detail libraries? I've been sifting through forums and other online sources without much luck. Any direction is much appreciated!
RDAOU
I am currently on the road, I will try to help u out once I get to a PC...unless someone else on the forum gets to it first...
"They say that one shouldn't text and drive but many of my peers seem to encourage me to do it more often"
Sent from my iPhone
Here is an example of a custom view organization.  Views are grouped by View Types then by Custom Folder name.  Custom folder is a project parameter assigned to the View category.  Judging by your screenshot, you most likely know it already.
I don't see a way to totally get rid of the view type designation from the Browser Organization as you asked, only be able to move them as a group headers so at least they don;t repeat for every view.
sbrandsrud
Thank you both for your replies! I discovered that our drafting views had several different "Types". I deleted these and lumped them back into one type and was able to successfully achieve the organization I was looking for. Thanks again for your help!
