levels missing
levels missing
Message 1 of 25
levels missing
Hoping you can help. I am missing some level anotations on my sections and elevations. Only one is showing up and I have several plan views.
I have tried propagate extents and maximize 3d extents and stretch out clip range of section to take up entire building. any ideas?
Eoghan
Replies (24)
Message 21 of 25
ennujozlagam
hi, same problem as yours, maybe could help you. read this
http://forums.autodesk.com/t5/Revit-Architecture/Levels-not-showing-in-Elevation/td-p/2680361/page/2
from Corey Daun solution. please see attached.
shalom...
Message 22 of 25
Hi eoghanharris, I have received your file and have solved the issue by following same steps I mentioned before. Now, all the levels are visible. I am sending you the file on your email id. I hope it will help you. Feel free to contact us in future in case of any query.
Tesla Outsourcing Services
Contact us - http://www.teslaoutsourcingservices.com/contact-us.php
Message 23 of 25
Thank you! This worked spectacularly for me!
Message 24 of 25
QUDOTECHPLUMBING
Observer
Observer
on link, it will show dim(under link). copy, and paste to same place.
Message 25 of 25
Clay_Kiningham
Was this ever resolved? I am having the same issues in Revit 2023.
[edit] Never mind - figured out the resolution.
