Levels in Elevation View Disappear
BigPicture045
Message 1 of 8
BigPicture045
This building uses separate levels than the rest in the project file due because it is on steep terrain.
It is "building D" and I have underlined the levels it uses. You can also see the typical levels the other buildings use:
The levels I need for building D are missing. I believe this happened when I changed the view port from scope box to cropped view. However, changing back to scoped box does bring back the correct levels:
See how the levels are missing below:
Replies (7)
Message 2 of 8
Select the levels in the 3D view > Right Click > Maximize 3D Extent
Message 3 of 8
Have you tried removing Crop and Revealing Hidden Elements?
Message 4 of 8
BigPicture045
They were there before. For some reason when I changed the view from scope box crop to a cropped region it removed the D levels.
Someone set this project up before me. I am not sure how they included the level D's in these elevations and not the other elevations.
@barthbradley They are not hidden either. I need the view to be cropped on the sheet. Using cropped or scope box and I don't see the level D's....
Message 5 of 8
BigPicture045
This is how it should display:
Message 6 of 8
The Levels have different heights. Did you accidently move their Elevation Base?
Scratch that. Misinterpretation on my part.
Message 7 of 8
BigPicture045
@barthbradley
Type D building has different Heights. That is my point. The other buildings in the file use Level 1, level 2, level 3, etc. Type D building uses level 1d, level 2d, level 3d, etc.
Message 8 of 8
BigPicture045
It was turned off via a filter. Thanks.
