Levels are not visible to my Autodesk Revit 2025. Help me please
ID010285
ID010285
How to visible Levels in Autodesk Revit 2025. Not clickable
constantin.stroescu
you have to be in a Section or an Elevation View in order to make the command visible
Constantin Stroescu
vitorbortoncello
like constantin.stroescu mentioned, you can see the levels in sections or elevations and also checking them in VG in 3D view
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
ID010285
Thank you I follow your instructions but didn't work. Still not showing in elevation view and section view and I'll check my visibility/graphics and check and still not showing the levels in Revit 2025
ID010285
ID010285
