Level not visible in north elevation but visible in all of the other elevations
buckley-j6
Message 1 of 9
buckley-j6
Hi everyone,
i cant understand why my there are 2 levels of mine that arent showing on my north elevation but they are showing on al of the other elevations fine. if anyone has any suggestions it would be appreciated personally i think it may be
something to do with the direction but i am unsure how to fix this.
south elevation working finesouth elevation working fineProblem elvation not showing external gl and mb ceiling levelProblem elvation not showing external gl and mb ceiling levelthe extents box for the external glthe extents box for the external gl
Replies (8)
Message 2 of 9
cbcarch
Try using a Scope Box and associate all Levels with it. (works well for Grids too.)
Also check "Propogate Extents" and right click on Level which is not showing and click "Maximize 3D Extents".
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 9
buckley-j6
i am new to revit how do i assign the level to a scope box? also when i click propgrant extents nothing is happening or coming up . i tried to maxmise 3d extents but again nothing.
Message 4 of 9
cbcarch
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/387...
Cliff B. Collins
Message 5 of 9
buckley-j6
i tried the scope box with no success i believe it is somthing to do with the direction of the level not going the full way around the building for some reason
Message 6 of 9
Revit_Whisperer
In order to see a level or a grid in a view...the extents of that datum element must cross the plane of that view.
I did a quick video on what I mean.
https://autode.sk/3tbK2Fj
Message 7 of 9
cbcarch
also check 3D and 2D extents.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN....
Cliff B. Collins
Message 8 of 9
cbcarch
The Levels are not Hidden in View, right? Or on the wrong Workset, which might be hidden?
Cliff B. Collins
Message 9 of 9
First thing I check it these situations is Phasing.
