Length parameter to annotation tag
Message 1 of 9
Does anyone know if we can add length parameter as an instance parameter for an annotation tag family.
I have a generic model family and I need to give some information to it and it varies from instance to instance.
So I need a tag family with length parameter for tag box which I could adjust.
Is there any way to achieve this by using conventional Revit methods or by Dynamo?
Thanks in advance..!
Replies (8)
Message 2 of 9
Looking for same concern.
Message 3 of 9
Alan.johnson1970
You create a shared parameter, add it as an instance to a dim (Label Dimension) in the generic family, and then create the tag and add the same parameter.
AJ.
Message 4 of 9
Alan.johnson1970
AJ.
Message 5 of 9
Alan.johnson1970
AJ.
Message 6 of 9
You can give an instance parameter to a generic annotation family and change it via properties in project. It does not wok with tags because tags are type based families.
Message 7 of 9
Alan.johnson1970
Here is an example generic model with a tag calling of the length which is an instance property
AJ.
Message 8 of 9
The question is about the length of the tag box, not the reported length of the host.
Message 9 of 9
Alan.johnson1970
Ah OK I may have miss read the OP then
AJ.
