LEGEND COMPONENT WRONG ORIENTATION
alejandroCH79K
Message 1 of 13
alejandroCH79K
Hi Team,
At the moment, I am working with a plate (Family) whose orientation is correct when I place it in elevation or 3d
However, when I place the family in a legend is rotated
i thought i did wrong the orientation in the family but no, in the family the orientation is correct.
any idea how to fix this? I have been 2 days on the phone with  autodesk support and they just told me to redraw it with detail line haha
Cheers.
Replies (12)
Message 2 of 13
edwin.prakoso
Does pressing space when placing the family help in correcting the orientation?
Does it happen in all files or only in a specific file?
Maybe you can upload the family so we can check it?
Cheers,
Edwin Prakoso
Message 3 of 13
alejandroCH79K
Hi @edwin.prakoso ,
Yes, at the moment, to place the family in a wall elevation or 3d, the orientation is correct, and the space bar rotates it before putting it
When I do this in the legend, the orientation is incorrect and does not rotate with the space bar.
Message 4 of 13
Orientation of element in Legend view is fixed and not always as expected (depends on family host type).  I suggest you nest the family in another family, rotate it, load it in the project and use it for legend.
Message 5 of 13
alejandroCH79K
Hi @ToanDN ,
That sounds like an interesting solution; how do I nest the family in another family?
Cheers
Message 6 of 13
- Create a new family
- Open your family and Load it to the new family, place and rotate
Message 7 of 13
alejandroCH79K
Hi @ToanDN
A metric Generic Model should be ok?.
Message 8 of 13
@alejandroCH79K wrote:
Hi @ToanDN
Yes.
Message 9 of 13
alejandroCH79K
I gave it a go, and it still had the same result, still rotated in the legend
Message 10 of 13
Did you rotate the nested family in the new family by 90 degree?
Message 11 of 13
alejandroCH79K
No, I Didn't, but all these plates on my wall. Do I need to update it to the new family (nested) and then rotate it manually?
Message 12 of 13
alejandroCH79K
Sorry ,@ToanDN , I tried again with a Nested Family even not necessary need to rotate in the nested family; it's working
now.
Thanks for the help
Message 13 of 13
johnl5PYL9
So many horrible workarounds! Just fix it! It's a decade or more.
