LEED 8.1 - Daylighting Analysis
Hi
I want to make a daylight analysis in Revit using Leed Daylight analysis. Unfortunately, it is not possible for me to make an analysis at a specific time, and I am missing the "run analyze" tab, as you can see in the picture marked with red below. I have downloaded the plugin, I am therefore very confused.
Does anyone have any good advice?
nmarcelis
I think you need to be in a 3d view to initiate the analysis.
Revit Certified Professional Architecture, Structure and MEP.
Thanks for the advice, but it doesn't seem to be working...
nmarcelis
Im not an expert in LEED lighting analysis.
Have you tried following the steps described in the following video?
I also attached a document explaining how lighting analysis works with Insight in Revit.
