- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I detail things using text and add leaders, with the straight leaders, when I come back to the view later, the straight leaders have shifted crooked a bit. Any thoughts?
Also, no mater how I change the span direction when making a floor with direction spaced lines, it won't change the lines. Am I missing something or should I just set up the lines at 90 degrees?
Thanks!
