Latest Updates | New Knowledge Network Articles | Revit Architecture
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Revit Architecture?
(List shown in chronological order)
 Subscribe to receive updates for new Revit Architecture's Knowledge Network articles.
For more updated solutions, also check out the Autodesk Blogs!
2016 Solutions 2017 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
March 2018
Underlay doesn’t display specific element
Dynamo add-in is missing in Revit 2016
Pipe appear disconnected if detail level is set to medium below
How to export to IFC only Structural elements
Color overrides from Revit model are not maintained after exported to Navisworks
Drag and Drop doesn’t work in Revit
C4R error: “You are not a member of any projects”
Autodesk Live - Failure to process a model
Can’t create new ceiling by Revit API
Revit - Cannot see cursor when editing text
Revit 2015 crashes when batch printing pdfs
Revit 2017 - changes saved by one user are lost when another user opens the model
Revit: Material transparency in 2D views
Revit: name and elevation of level don’t show in elevation views
Revit: Service Unavailable error when signing into A360
Revit:Cannot export element lists
Revit-Blue screen when printing to FoxIt PDF
Datum height of toposurface does not match datum elevation height points
Deleted model in BIM 360 Team still appears in REVIT
Error exporting Revit to Advance Steel: Advance Steel Extension encountered an error. We are sorry f...
How to model clearances zones for MEP
How to set default location of user Revit files for all users logging into computer
HTTP Error 503 Service Unavailable
Nested Generic Annotation family with masking region does not appear in Coarse in Hidden Line mode
Revit - moving mouse cursor over the buttons on the ribbon is causing the buttons to expand in size
Revit C4R model crashing on some computers when editing an element
Revit Error - “Can’t use this type in this host”
Revit Objects disappear while working on the model
Revit Server: Multiple binding causes error browsing SVCs
Small rooms are ignored by room tool
When loading a Revit family and placing it, a different family appears
DWG display in different way in Revit as expected
Collaboration for Revit: Models containing links to other BIM 360 Team projects block Publish operat...
No flow value even though ducts are connected properly
Scale command won’t scale beyond a certain size.
Collaboration for Revit: Publish Latest fails; journal includes “InternalServerError”
How to check performance for VR before purchasing VR headset
Revit - COBie parameters not populating
Revit does not launch
Revit sheets uploaded to BIM 360 Team are blurry
Revit: Elevation view is missing from project
Revit: How to assign unique values to doors in a linked model when multiple instances of that model ...
Adding a tag takes longer than expected when there is a link file
Revit: How to place truss so that the top of it attaches to the level
Revit: Spinning cursor after launching
A360 cloud rendering doesn’t have transparent background
C4R- 3D view published to BIM 360 Team does not show entire model
Collaboration for Revit: no projects are shown when clicking on the BIM 360 icon in Revit
Elements have duplicate “Mark” values - how to remove them?
Error when trying to copy model group - Group instances of the same type do not contain identical me...
Global control on assambly codes
How to edit text in Graphical Column Schedule
How to mirror Revit window family
Parent case 13828284 - Investigating Journal data
Revit - compressing walkthrough videos
Revit 2018: most of project browser and/or properties dialog is blank
Revit Integration with Robot-UnKnown runtime error
Revit: Fixture Units in a stack don’t propagate through the stack
Revit: Model {Filename.rvt} is being accessed by someone else and is not available.
Revit installer closes unexpectedly
Revit Live: Conduit fittings are showing in incorrect locations
Revit: Live wants to connect to “My Documents” in the C:// which creates issues with the backup and ...
C4R: When trying to open a file from BIM 360 Team, the loading process doesn’t finish
Can’t save Revit “template” (.rte) file as a “project” (.rvt) file
Collaboration for Revit: The data in is corrupt and needs to be manually recovered
How can I modify and save as new Revit Window Family
How to tag top and bottom of pipes in Revit.
Insight lighting analysis cloud credits cost
Reference level changed after copy a group
Revit: Can’t see doors in plan view inside a plan region
Revit: how to assign different circuits to the same component
Revit: inaccuracies and poor definition in pdfs
Revit: Slow synchronization and file opening for a C4R model
The request could not be performed because of an I/O device error.
Collaboration For Revit - Communicator will not start
Discipline Heating is missing in Revit
IFC export from Revit generates numerous levels
Pipe not visible in plan view but visible in all other views.
Point Layout Plugin fails to get license in Revit 2017
Revit 2017 won’t open after installing HP printer driver
Autodesk Revit fails to print to PDF
CoBIE Extension for Revit fails to export types and components
How to import Navisworks file \ model to Revit
Revit: How to add blank lines to text list without restarting numbering
Autodesk Revit - Wrong Bolt Length
Collaboration for Revit trial error: You do not have access to C4R
Error: “File not saved” when saving a family in Revit
Labels are broken when exporting DWG in Revit 2018
No contracts available when trying to assign Team subscription
Revit - Cannot see point cloud
Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Revit - Crashing when modifying spool sheets
Revit Fitting missing linework on one side.
Revit: Can’t export updated nwc files from Revit
Revit: How do you save Revit project as RVT when you accidentally saved as RTE
Revit: one of two demo'ed curtain wall is not visible in a plan view
Revit-Annotations are missing when opening a Revit file
Collaboration for Revit - Create New Local option is grayed out
Wall closure parameter in door and window families
How to change display of units on levels in Revit
How to change value of default parameter inside family
How to edit section head
Revit - Windows 10 - Text size and boxes appear larger in print preview and prints
Revit error: Central model is not accessible
Revit Server error “Revit cannot perform this operation because you are trying to access a file or f...
Revit stays spinning forever when renaming views or sheets
Revit: Can you change a rectangular duct system to a round duct system?
Revit-Constraints are not satisfied when setting a family parameter to a nested family type
Revit-Door schedule shows many doors that are not in the model
Slow performance when using eTransmit with a Revit model containing Revit Server links.
Use stacked dimensions in Revit
February 2018
Revit Live 2.0: can’t make edits as in previous versions
Revit Live: selected views do not show up until Go Live is run a second time
It’s not possible to create floor in Revit® from sketch lines with pick line tool.
It’s not possible to start Formit
REVIT – How to fill all empty cells for a given parameter in schedules
REVIT – How to purge unused shared parameters in a project
Revit 2017 crashes at specific model at COBie extension
Revit Live: window glass is so transparent it’s not visible
Revit Steel Connection 2018: Error “Your SQL Server installation is either corrupt or has been tampe...
Revit: Edit view title to exclude scale and only show title
Revit: How to restore work by running a journal file
Revit crash while login into A360 services
Can not import dwg file into Revit
Cannot adding dwf sheets from Revit into Auotdesk Vault
IFC Link from Tekla does not appear in Revit 2017
Cannot create a copy of a group identified as same group
Does Revit Architecture, MEP, Structure 2018 available?
How to download Revit tutorial files
Imported or linked CAD drawing will not show up in a Revit view
REVIT – Phasing - How to avoid demolished objects to cast shadows.
Revit Cloud Rendering Fisheye Download Option
Revit: Can’t close load family dialog box
Revit: Collaborate tab is greyed out and not able to be initiated
Revit: Unable to print linked model in a section view
How to include people with realistic display in Revit Live scenes
Revit Live 2.0: Filtering unwanted elements in a linked model does not work
Revit Live FAQ: file storage, security, deletion
Rich Photorealistic Content (RPC) in Revit Live does not display the same as in Revit
Revit LT 2018 - “Failed to save document” error when saving to network storage
Autodesk Revit is not pulling a license from the license server
AEC: Multidisciplinary Workflows Between AutoCAD Plant 3D, Revit, and AVEVA PDMS
Export IFC - elements have wrong material parameter when additional painting has ben added
How to display Moment Connection Symbol
How to place horizontal air grille on duct
Imported DWG into Revit container file cover room color scheme in Revit 2017 while export to DWG
Lines with line weight smaller than 0.1mm will be printed by 0.1mm
Model is slowing down while changing wall type to another on existing wall
Multiple Revit files will not open
Pipe accessory K-Coefficient from Table is missing in Pipe Pressure Loss Report
Revit Error: Revit could not save all of the worksets that have been changed
Revit- Shortcut for 2D Mode does not seem to do anything
Revit: Manage worksets dialog results in error: “This operation could not be completed”
Revit: non-room-bounding walls act like they are room-bounding
Revit: repeated model and .slog corruption
Revit: Rounding temporary dimensions
Revit: Text overlapping in print preview and printing to PDF
Revit: Transfer Project Standards fails for view templates between two specific projects
Revit: Wall by Face command gives error: Can’t make Face Wall shape
Where I can find additional Revit Content
How many Revit versions does Collaboration for Revit support?
How to create an insulation on a cable tray in Revit?
Revit: Custom family showing through roof in elevation view
Can coordination models be exported to Autodesk Live
How to create a new level in Revit?
How to transfer view template from one view to another view
Inconsistency in copy/ paste of walls
Inconsistent behavior of grid lines in crop region
Print issue at specific file
Updating links both the new and the old version of the link appear in the project
How to turn on snaps in Revit
Unable to install Revit 2018.2 update
How to add “Nordlicht” to a specific surface?
Revit - Fatal Error after e-transmitting a model
Revit 2018 - Linked Coordination Model (NWD) not visible in section views
Revit- Moving Topography causes topography contours to shift
Revit Server process cannot access file because it is being used by another process
Revit- Structural Framing elements are not exported to correct dwg layer
Revit: can’t “go Live” from a camera view
DWG import: site reference symbols get lost
4K Revit UI - Open dialog text not readable
Is it possible to calculate Structural Section Properties in Revit?
Revit closes mid session
Revit Saving locally is slow
Revit-Certain text characters overlap when printing
Section line in depended view does not appear while DWG export from Revit
Revit - External Tools - Add-in Assembly Not Found
You want to know if it’s possible to install Inventor 7 on Windows 7/8/10
January 2018
Unable to access C4R projects when more than one Revit version is open
Revit - Creating ribbon button failed when starting Revit
Revit 2016 will not start after update of Antivirus
Revit 2017 hangs on splash screen during launch
Revit crashing when printing to pdf with Bluebeam
Revit File crashed before saving; can unsaved changes be recovered?
Revit file size increased due to ElumTools
Revit Live - fatal error while publishing to zip
Revit Live: No background terrain in scene
Revit performance expectations: file size vs network latency
Revit Server 2017 cannot install because error 1603 occour
Revit- Sheets are not centered when exported to dwf
Revit: Auto-generated wires are not masked by lighting fixtures
Revit: Best practices for building families
Revit: Can’t export all views and sheet to ACAD - only one sheet in export list
Revit: Create instance parameter for data outlet sequence number that will automatically update
Revit: Error exporting data to DB Link - the field is too small
Revit: Exporting linked model with linked DWG puts DWG on Layer 0
Revit: how to change defaults from metric to imperial or vice versa
Revit: How to leverage the features of the Autodesk COBIE Extension
Revit: How to switch fabrication configurations
Revit: icons and text in dialog boxes are overlapping on Windows 10 computer
Revit: Insight Solar Analysis plug-in expired
Revit: Linked DWG files are not at proper scale
Revit: Linked file references wrong model and indicates a local alias in the manage links dialog box
Revit: Rebar jumps or snaps to another location when moving
Revit: recommended workflows and best practices
Revit: Reference label missing from callout tags
Revit: sheets printed on HP DesignJet have wider margin than expected
Revit: Some parts missing after Importing .MAJ file into Revit
Revit: Views are printing pixelated on some sheets and not others.
Revit: Windows 10 crashes and has become unstable after installing the product
Revit-Cannot see points imported from Point Layout.
Road’s profile gets raised up after importing from C3D dwg into Infraworks
Can Revit MEP model drain services
Collaboration for Revit - Model links not updating
Do the links which are RVT central files in the same C4R project reload automatically?
Autodesk Revit Live Service 2.0.0.876 - issue with surface rendering
How to download previous version of Revit Live
Revit Live 2.0 the new .lvsc file format replaces .lvmd
Fatal Error: “File does not exist ‘exploded_database_db’” when launching Autodesk Live
Autodesk Live 2.0 Viewer
Materials of the linked models are not included and turn white in Autodesk Live
Error: Revit LT has stopped working
Revit LT 2018 does not start after windows update
Revit LT Model in Place not available
Where I can find list of all software included in AEC Collection
Warning at starting Revit: “Failed to initialize the add-in "Model Review” because an application al...
Is Structural Analysis Toolkit for Revit 2014 still available
Missing elements on printout with vector processing
How to create section line with different angle
How to dimension rotated elements in linked CAD file in Revit
How to transfer Revit model to Midas
How to compare differences between BIM model and point cloud data
How to copy views from one project to another
Images assigned to custom parameters get lost at IFC export
Reinforcement cannot be placed into specific rebars
File not saved during synchronize with central
Error related to temp folder when installing Revit
Error running Analysis in Cloud after Changing Members with User Defined Section
External Tools - External Tools Failure “Revit 2017 cannot run the external application "Collaborate...
How to change format of Date/Time Stamp in Title Block
How to get area of ducts, duct fittings and mechanical equipment
Random lines showing in camera view when printing
Unable to use Revit Steel Connections Add-in
C4R error when opening: This operation could not be completed, please try again
Can’t filter by system type in pipe/duct fitting schedule
Cannot install Revit 2018
Cannot select distribution system from drop down list
Collaboration for Revit: Cannot open C4R certain project from specific computer
Elements are not shown in the underlay
Error message when trying to open Autodesk Revit
How to transfer and use results from Dlubal in Revit
How to work together with Revit 2018 and Excel?
Is it possible to import the saved views from Navisworks when linking the coordination model
When you launch Revit, on the top, states “Autodesk Revit - STUDENT VERSION” even though you have a ...
‘System.TypeInitializationException’ error when launching Revit 2016 after installing Collaboration ...
Font spacing is incorrect when a PDF is printed from Revit 2018 on Windows 10 Bootcamp
How to customize electrical families
I can’t draw any pipes
INCLUDE_BORROW not showing date range as expected
Revit - Closed worksets from nested links are visible in host file
Revit - Creating multiple groups of electrical devices in a circuit
Revit 2018 stop working after Windows 10 run updates
Revit 3d views and perspective views jump to new location
Revit DWG Export Modifiers for Level not working for Structural Framing
Revit: Exported IFC file does not contain the custom parameters from Revit after re-imported into Re...
Revit: is it possible to import files into a Revit project with viewer mode?
How to change Langauge in Revit 2017
How to export model from Revit to IFC export with quantities
How to change Revit user name for workshared project
How to make Steel Fabrication drawings from Revit
IconEditor.exe - Error 1309.Error reading from file:
Installing Autodesk Shared Reference Point for Revit 2018 you get the error: “This extension require...
It is not possible to connect different sizes of sanitary piping
Master List of All Revit MEP Parameters
Not possible to import DWG to Revit
Revit - BIM 360 icon is missing in the “File Open” dialogue box
Revit - External Tools Add-in Assembly Not Found - Site designer
Revit PDFs of some sheets are extremely large and take long to print
Revit: Zoom Extents on sheet is unexpectedly zoomed out
Revit:Is it possible to display elements in phase filters controlled by phase override settings defi...
Matt DiMichele
diana.yr
 August 2018
error: “An unrecoverable error has occurred. The Program will now be terminated. All of your data ha...
Blurry resolution in Revit since Parallels update
Find save history of a Revit file
How to recover unsynced and unsaved changes to a Revit model in cloud shared workflow
Model space gets blank when moving the Project Browser or changing the size of the window in Revit 2...
Prerequisites for Revit 2016
Prerequisites for Revit 2017
Prerequisites for Revit 2018
Revit instability (repeated errors or crashes) due to missing or damaged prerequisite software
Linked files are not visible when opening the Revit parent file in A360 Drive
Prerequisites for Revit 2019
Cannot access the ‘architectural’ folder in Collaboration for Revit 2016/2017
Deleted cloud model still appears in the Open file dialog window in Revit
Is it possible to sync Revit projects in BIM 360 Docs to local drive or external server?
The default beam centre justification set in Revit as top is changed to middle line in Robot
Restore a previous version of a Revit Server model without losing the current model
View Template property changes to None when template is applied in Revit
Spaces do not match the rooms of a linked model in Revit
Open or Save As dialog window in Revit does not respond when clicking on the available buttons
Revit Insight Plug-in shows zero credits available
What is preventing selecting of Autodesk Point Layout Points in Revit?
Some 3D views are blank when opened in Revit
Can’t close Revit files without saving file or forcing close
IFC export problem at using linked files with design options in Revit
Walls exported to IFC from Revit and opened in Navisworks only have three layers with no internal co...
Error: “An unrecoverable error has occurred. The program will now be terminated” - opening Revit 201...
How many concurrent users can synchronize to central on Revit Server
Error when moving the project base point in Revit
Model lines change position when exported to IFC in Revit
Linked IFC files in a REVIT project are offset according Z axis.
Reinforcement cannot be added to demolished elements in Revit
BIM 360 Docs is slow when extracting views published from Revit
Can Revit models be downloaded from the Rendering Gallery
Cannot place specific generic models with small gaps
Change in Windows drag and drop setting prevents Revit views from being moved to another monitor
Crash/freeze when opening views or sheets in Revit when a link is loaded
Custom Roof Truss Family with Web breaks when flexed in Revit
Drawing error or Unrecoverable/Fatal error while working in a Cloud workshared Revit model
Error: “A serious error has occurred.” when loading a family in a particular file in Revit
Error: “The central model cannot be found, perhaps due to a lost network connection” when syncing in...
Error: “You do not have access to the BIM 360 Team project for this model” when trying to open a clo...
Revit crashes when closing Dynamo
Suppress Auto-loading of Communicator in Revit
Text is wrapping in Revit 2018 on one computer
Unable to copy and paste elements between Revit models
Cannot place model lines in specififc view
Can’t put dimensions on a curtain wall in elevation in Revit
July 2018
Circuit path is going to project origin instead of the power panel in Revit
How to create VR view from an Autodesk Stereo Panorama rendering
How to join an existing BIM 360 Team project without activating new BIM 360 Design Account
Point clouds do not display in Revit for files transferred from one computer to another
“Inconsistent units” when creating formula for a schedule in Revit
Drafting Views placed on Revit sheets have large crop boundaries
Enhanced DWG export options for Revit
How to use a group of 2D detail elements in different C4R projects
Issues with text when printing from Revit
Revit shuts down during Link IFC
How to assign names to split faces within a project in Revit
Unable to use BIM360 Design Collaboration in releases previous to Revit 2018.3
Error during Revit installation from deployment: Source file not found \Revit2018\Img\x64\MEP_Fab\Fo...
“Error - cannot be ignored” when moving or making an edit request to a Revit family/component
Ceiling pattern showing through light fixture in Revit
Energy analysis fails with imported IFC model in Revit
Error: “You are not a member of any projects” when trying to open a C4R model and access a project i...
Graphical Error: When working in Revit plan/3D views, lines are displayed which spread out from the ...
How customize view numbers on Revit sheets
Revit could not load C:\Program Files\Autodesk\Revit 2018\BUILDINGSYSTEMSDB.DLL when Revit launched
Room color schemes from Revit are displayed as black and white in BIM 360 Docs
Schedule does not display parameter values for certain categories in Revit
Some objects show in random locations after exporting a DWG from Revit 2017
Unable to view RealView information when point cloud data imported in Revit
Dimension value is not being accepted when the value difference is very small in Revit
Error: “you are not a member of any hubs” in Revit 2019
Export IFC which contain hierarchy parameter within Revit assemblies
How to create a new material type for Revit pipes?
How to get wall wrapping at inserts to wrap to outside of core boundary in Revit
Linked Revit models loose their path and name once cloud model is overwritten
Loading a Family into a certain other Family or Project changes Parameter grouping
Locating the Frame Generator for Autodesk Revit
Projects on BIM 360 do not show up in Revit, but you have access through the website
Purging unwanted dimension and viewport styles in Autodesk Revit
User is signed out of BIM 360 immediately after signing in from Revit
Wall opening in new objects does not cut through wall properly and shows as red in Revit
Why extra charge is required when running daylight simulation in Revit and how to count the cloud cr...
Workflow for incorporating IFCs into a cloud Revit project
Installation Error: 1920.Service Revit Server AutoSync 2017 (Revit Server AutoSync 2017) failed to s...
June 2018
How to bring Autodesk Live model changes back to Revit
Revit Steel Connections in Revit Live
Unable to run Revit Live 2018 as a network license after running in trial mode
Can’t access Revit Live from Revit 2019
Issues moving around in Revit Live with HTC Vive VR
Merged objects have only level info displayed in BIM info in Autodesk Live
Content missing after installing Autodesk Revit 2019 LT
Crashing when using Revit LT with Parallels on a Macbook
“Go Live” button missing from the ribbon in Autodesk Revit 2018
Lag when modifying Tags in a Revit model
Can you control worksets for linked models in Revit
Can’t Trim or Extend Revit Splines
Collaboration for Revit: Local links not visible on the cloud
Crashing in Revit only when creating a local model
Error “DBApplication startup failed because an error occured from OnStartup” when launching Revit 20...
Error: “No access to project” and “Can’t connect to central model” when opening Collaboration for Re...
Fixture cannot be placed in ceiling when created in a different phase in Revit
Getting “Improper Use of Boolean Expression” message with Revision Number used in calculated value i...
How to disable the Desktop Analytics Program in Revit
How to Include Revit 2019 add-ins and updates with a deployment and install silently
How to update group of the same Steel Connections in Revit
Insight Error: Unable to get results from the Rendering service
Installation for Revit fails at the installation of Dynamo
Is it possible to mirror a view in Revit without mirroring the modeling elements?
Limited list of families available in Revit
Revit fatal error occurs when editing a curtainwall
Revit: Analyze Tab missing in the ribbon interface
Revit: Upgrading computers from Windows 7 to Windows 10
ROBOT - is model imported from Revit automatically meshed?
Section View not showing a cut in angled Wall in Revit
Steel Connection warning in Revit: “Incomplete Structural Section Parameters”
Warning: “The shapes for medium and fine detail levels of connected element are inconsistent” while ...
2D sheets from uploaded RVT assembly show up as raster images instead of vector drawings in BIM 360 ...
Error: “An unrecoverable error has occurred…” when opening views in Revit
Windows Insider build and Revit instability
“Inconsistent units” when creating formula for calculation in a family in Revit
Dialog box position not saved after closing Revit
Duct lining does not show in Hidden Line but does print in Revit
Hovering over a command on the ribbon in Revit and pressing F1 does not bring up help topic
How to make a lap splice for area reinforcement in Autodesk Revit
June 2018
May 2018
Revit Live processes only partial file \ model (Links excluded)
Is It possible to run Revit Live 2018 as a stand alone EXE on any system without installation?
Exporting a Walkthrough from Autodesk Revit results in a blank avi file
Error 1603 when uninstalling an Autodesk program
Blank views when creating new views in Revit
C4R / BIM 360 icon disappear from Revit 2018 “Open Project” windows
How to create a Revit Template from an existing project file
Reinstallating Collaboration for Revit (C4R)
Release information: BIM 360 Design
Revision sequences do not appear in Sheet Lists in Revit
Revit 2017: Cannot sync a model to the cloud in Collaboration for Revit
Revit and Revit Live will not open after Windows 10 Update
Revit Server Roadmap
Revit: IFC Import/Open takes a very long time
Revit: snapping to end point of an In-Place Family does not display the endpoint properly
ROBOT2REVIT-link: Revit is able to receive the structure from Robot Structural Analysis Professional...
DWG Export hidden lines - some lines are missing
Revit - Can’t link in files that are in BIM 360 Docs into Revit model
Revit 2018: ‘Worksharing conflict’ due to username change after logging in to A360
Ability to disable checking for updates for Autodesk desktop connector
Advance Steel - Revit SMLX export-import: The system line position change when import in AS
Can’t delete Revisions in Revit
Error: “Unable to Access the Model” message when trying to sync in Revit
Fabrication CADmep: missed geometry on imported Revit Families
Get Up to Speed: Autodesk Revit 2019
How to access the “Learn everything about Autodesk Insight” webinar series
Released Revit 2019 Updates & Add-ins
Revit - Error: Unable to bind selected link
Revit: How to remove duplicate project parameters
Revit: include static pressure in schedule or pressure loss report
Collaboration for Revit - User cannot save adjusted publish settings
Point Layout Error when clicking on Settings from within Revit
April 2018
Revit-This Local File has been saved by user….Please change your user name or stop working on this f...
Revit - Electrical families don’t allow assigning of a system distribution
Revit: Hatch pattern does not entirely print in section view
Revit: Wall with glass layer makes entire wall transparent in 3D view
Network Deployment Revit Architecture 2016 R2 update not showing in Application Manager
Product updates are not showing up in Application Manager at the end of creating a deployment
Relog into Revit when working with BIM 360 Team project
Revit - Crashing when creating a local file
Revit Eurocode Steel Profile
Revit phases: disappearing window in floor plan view
Revit Server Administrator (2018) is not available
Revit Server Errors encountered when browsing SVC files
Revit split segment restricted
Revit: Elements above or below the current View Range are unexpectedly displayed in the view.
Revit: Is it possible to turn off background Volume Calculations
REVIT: Rebar Hook 90° length parameters issue
Revit - Cannot place spaces in a project
Missing option to export Revit model to Navisworks (nwc file)
Is it possible to use lookup table function in system families
How to minimize the storage impact of a file-based workshared Revit model.
How to split the component in Revit family editor
Foundation patterns
How to place Filled Region under 3D Elements and keep their visibility
Is it possible to edit the linked rvt file directly in host file just like editing a family in the f...
ReCap: Can I generate an URL link to my point cloud and link it to an object in Revit?
Revit - Imported mechanical equipment family does not show up in any view
Revit - Upgrading models from 2016 to 2017 deletes views
Revit Edit In-Place - all elements in view are not visible - geometry disappear
Revit: Graphical “noise” in solar studies and animations
Revit: How is the Critical Path determined and calculated on a Duct Pressure Loss Report
Revit: How to get the best quality renderings
Revit: Some buttons are missing from the tabs or ribbon
Revit Phases: strange display of window in Section view
Revit: materials assignment or editing in Rhino 3dm file imported into Family
Can’t use the in place void component to cut the structural element
Collaboration for Revit: updating linked models when linked model display is set “by linked view”
Dalton plugin has retired
Desktop Connector is failing upon system startup
Error 1909 when installing Revit 2018 content libraries
Collaboration for Revit: Communicator will not sign in
Flow values are not calculated correctly in the certain parts of a specific duct system depending on...
How do you install Revit Vault interoperability if Vault Server is already installed?
How to show texts and dimensions from family in project enviroment
Insulation shows as a box when adding on the complex pipe fitting family
Nested shared mep family causes strange behavior in project
Offline Revit 2018 Help for download
Revit family cannot be edited
Revit phases: black surfaces in 3d views
Revit: IFC export nothing is output
Revit: Orbit command causes crash
Revit: Spot elevations display top elevation values even with bottom elevation specified
Support missing for Stair element in Revit
BIM 360 Glue: Element properties missing from a model glued from Revit 2017
An unrecoverable error has occurred launching Revit 2016
Project parameter locked by View Template can still be edited
How to pass air flow through Revit MEP duct accessory
Revit: Section marks disappear in plan view when cropping the section view
Can not annotate room from linked Revit model
How to control color of pipe or duct center line
IFC Export with errors with IFC exporter 18.3.1
Nested detail item display issue in section views
Revit - RPC not appearing when Rendered
Revit: Array command does not hold a consistent horizontal datum
Revit: Shared Parameter for Wire Type Family works for Tag But Not for Schedule
Diana Rouge
Social Media Specialist
diana.yr
October 2018
Calculating building cubature in Autodesk Revit
3rd party true type font in Revit larger than other programs
Can not place MEP Room Annotation in Revit
Can’t align coordinates between Revit > Navisworks > Civil 3D
Error: “Unknown run-time error” reported while transferring model from Robot Structural Analysis to ...
Error: “You don’t have required permission to perform this operation” when accessing BIM 360 Team
Hang when sectioning Revit model
How to adjust the scale format in view schedules in Revit
How to create scalable cut pattern in Revit
How to get pipe length in Revit
How to make pipe spot tag for invert elevation in Revit
How to split a long schedule on multiple Revit sheets
Is there a way to link keynote files in Revit using BIM 360
Return Air Flow rate calculation incorrect in Revit
Revit Add-Ins not showing in the ribbon tab
Runtime error during export of Robot model with RC columns or beams with complex shapes to Revit
Where to get Revit 2018 content which looks similar than content for Revit 2019
Revit can not open files after reinstallation
The open dialog window displays an A360 button instead BIM 360 Team in Revit 2017 and files show as ...
Cloud worksharing file takes a long time to publish to BIM 360 Document Management
Cannot see updated Revit model in BIM 360
Error: “Room is not in a properly enclosed region” in Revit
Error: “The project cannot be saved because the user name is not the same” within Revit
How edit a lookup table for a welded socket to suit BS1740
Railing appears continuous and intersects with post in Revit
Unable to access Revit 2019 cloud models in BIM 360
When creating an sxml file with Advance Steel Extension, Revit crashes
Error: “A serious error has occurred.” when creating a curved stair in beyond limits in Revit
Error: “Deep Indexing of ‘.rfa’ (ResourceId: 62) failed” when Vault was installed with remote SQL Se...
Opening by Face doesn’t work on some steel beams or columns in Revit
Survey coordinate points are wrong in Revit when using Point Layout
Files published from Revit Live are too large to email
After upgrading the Vault Server the Revit Indexing Service does not work
Floor Finish and Ceiling Finish parameters not filled with data in room tag in Revit
Initiate button is inactive when collaborating in the cloud from Revit
Is it possible to get structure components from Revit into AutoCAD Plant 3D?
Model Checker vs Model Review for Revit
Cannot change between the project phases after uploading a Revit model to a BIM 360 project
Recessed lighting fixtures placed on linked model do not calculate correctly with lighting analysis ...
Cannot export to .IFC file format from Revit 2017
Wall by face tool on certain mass generate incorrect walls in Revit
Error: “.rvt not found. The link will be unloaded.” appears when linking a Revit model from BIM 360 ...
One or more 3D views in Revit appear pixelated and transparent regardless of the visual style
Site survey point changes position (moves & rotates) when it is reloaded in the site file in Revit
Structural column not visible in coordination plan view in REVIT
Groups move or shift after being reloaded in Revit
Information about Revit Schedules and capabilities
Mass update for Material Asset replacement in Revit
Elements appear wireframe in Revit 3D view in every visual style
Steel shop drawing IFC file not imported to Revit
NWC Export from Revit missing links
Error: “Fatal error! Assertion failed…” when opening model in Revit LIVE
Long delay when editing filled region boundary
Cannot attach walls to indicated in-place floor in Revit
How to calculate wall quantity considering rough height and width of door openings in Revit
There are duplicate instances of a linked CAD file in the ‘Imported’ category for Visibility Graphic...
Error: “There is already a Revit model with the same name in the selected folder. Please use a diffe...
Are non-structural Revit model elements exported to Robot as loads?
Generic Annotation family is the wrong size on one sheet or view in Revit
Can BIM 360 Design Collaboration be used with previous versions of Revit?
Cannot find Revit extension for Revit 2019
Drop Me functionality is grayed out on a floor plan published to BIM 360 Design Collaboration
Duct Hidden Lines not showing in Revit
Creating Life Safety egress paths in Revit
How to create Point Sets in Revit for use in BIM 360 Layout application
Panel schedule template borders are missing in Revit
How to work with shared Revit project from home
File size increase and slow opening Revit cloud workshared model
Unable to change view scale in Revit - grayed out.
Navigation Bar or other UI features are missing in Revit
What’s the URL address for a BIM 360 Document Management account?
Wood framing design in Revit
September 2018
Some elements are not selectable in Revit model
Renaming Revit View Templates in Dynamo
“Downloading Source File” of Previous Version of Revit model causes “Failed to open document” when o...
Error: “Install Failed. Access is denied.” when installing Revit 2018.3.1 hotfix
How to change one dimension value between chained dimensions in Revit
How to export inner and outer walls to different dwg layers from Revit
Keynotes numbered “By Sheet” don’t update when an element’s type is changed in Revit
Error: “An unknown error occurred while accessing (TemplatePath)” when linking IFC file in Revit
File section of Print dialog box is grayed out in Revit
Revit shared parameters do not appear in title block
Unfindable Room in exported database when using DBLink in Revit
Background processes of linked models in Revit
Model view is blank in Revit
Using BIM 360 Team and Docs concurrently with Revit cloud worksharing
Image scrambled when printing to pdf from Revit on Macbook’s parallels
Text does not display correctly in Revit on different systems
Unable to publish shared coordinates for BIM 360 Design (C4R) models
Using Route and Fill only shows one solution in Revit, while multiple solutions are shown in Fabrica...
How to get weight of duct fittings in Revit
Cannot change phase of default 3D Revit view in the Online Viewer
Error: “Internal Error 2920” when trying to repair Revit installation
How to import a toposurface from Revit into Civil 3D
Model fails to publish in BIM 360 Document Management
Render materials change color when rendering in cloud from Revit
Revit stalls after updating Windows10 to build 1803
The load family dialog goes to the last browsed location instead of the default library in later ver...
Unable to dimension for the elements that are not visible in the view in Revit
Using keyboard shortcuts causes a delay with mouse clicking in Revit
Using parametric cuts causes start and end parameters to be lost in Revit
Error: “An unexpected error occurred” when accessing Revit Server Administrator and users are unable...
English warning in non-English Revit user interface
Rebar cover cannot be applied to combined elements in Revit
Where to download Revit Server 2015 installation package
Baking lights from Revit Live to Stingray 2016
How to change the pipe weld thickness in Fabrication
How to customize Omniclass txt file for Revit
IFC Export contains double entities for the Revit Roof categories
Error: “There are no models in this project” appears when trying to access BIM 360 models within Rev...
How to modify imported DWG content for an DWG export in Revit
How to view Revit and Navisworks files on an iPad, tablet, or mobile
Transferring a .dvs file from Revit to Navisworks prompts a BIM 360 Sign on request
Error: “A Serious Error has occurred” when importing or linking a specific DWG file in Revit after e...
Error: “The project cannot be saved because the user name you are using is not the same as the user ...
Latest changes made to Revit cloud model are not reflected in BIM 360 Docs
Pressure Drop Calculation in Revit from a Plant 3D link
Crash when inserting a family into Revit
Deleting a light fixture from a ceiling is slow in Revit
Objects are partly whited out and do not display in hidden line view in Revit
Revit does not load changes made in a Fabrication database
Unable to access Revit 2018 cloud models in BIM 360 Document Management
Diana Rouge
