Latest Updates | New Knowledge Network Articles | Revit Architecture
Azmeera.M
Alumni Alumni
Azmeera.M
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Revit Architecture?
(List shown in chronological order)
 Subscribe to receive updates for new Revit Architecture's Knowledge Network articles.
For more updated solutions, also check out the AutodeskHelp Blog!
Azmeera M.
Autodesk Employee
Azmeera.M
ARCHIVE
January 2016
An AutoCAD dwg imported in Revit results in a wide zoom extents
Buildingbook extension - room part quantities calculation and phasing
Carbonite stopping Revit from syncing
Changes to a point cloud .rcp file are not displayed in Revit after the file is reloaded
Customizing arrowhead of the stair path symbol
Door tag label in Revit get shifted when rotating
Energy Analysis error: “… Unable to analyze…” (Revit)
Energy Cost Range tab missing from Results & Comparison dialog
Error: Energy Analysis - “There has been an unexpected problem. Unable to Analyze?
Exporting assets from Autodesk Revit to Building Ops
File won’t synchronize
Hidden areas and room separation lines in Revit project
Hidden subcategories in Revit view
IFC export doesn’t consider mapping file
Inconsistencies at dimension references at the usage of “Cut geometry” / “Uncut geometry” commands
Missing drawing lines when importing CAD file into Revit
Reinforcement elements are not shown in section views that have a segmented section line
No global binding for HTTP prevents installation of Revit Server
Properties palette shows two “End of Referenced Element” parameters for structural braces
Proxy Server and domain exceptions for Autodesk A360 services
Render command is grayed out
Revit | Toolclip video doesn’t work anymore
Revit: Wall sweep of architectural wall appears in the structural discipline
Revit: Override graphics in view by category for Revit links not propagated to visibility/graphics o...
Transmitted Model dialog unexpectedly appears after file from eTransmit is resaved in Revit Server
Revit 2015: UR11 breaks Revit Server
Revit Server Installation failed
Revit: The user interface of Revit may turns to Chinese
Solon tab is blank for Windows 10 systems
Some or all colors in a color scheme are suddenly changed (Revit 2016 R2, Revit LT 2016 R2)
Structural beams disappear from floor plan view after being joined
Surface representation component in Revit family gets cut unpredictably
Unremovable duct and pipe insulation in Revit MEP
Using formula to define roof slope in Revit
Wall opening height is missing in Revit dimensions
Wrong program opens when accessing help from Revit
February 2016
Activating beam system tool causes Revit to lock up
After installing the new version of the Autodesk BIM 360 Revit Add-in, Autodesk Revit shows error me...
Architectural walls appear in a structural plan view
Can’t connect to Revit Server Accelerator
Converting fabrication content to Revit families
Copying a window into wall loses the new host in Revit
Daylight factor calculation in Revit
Error “Can’t create swept blend”
Error “One or more errors occurred” displays when updating a model from Revit into BIM 360 Glue
Error 1606. Could not access network location when installing an Update Release for Revit 2015
Error upon loading wall-hosted family: “A serious error has occurred”
Error when importing MAJ file in Revit
Error: “No element in a secondary Option can be referenced by an element outside that Option”
Error: “Nothing will be divided” when creating parts
How to modify Top Railing Type properties for Revit railings
How to set Revit Work Plane
How to switch the orientation of a sloped wall in Revit
IGS import into Revit: When using the Revit to Robot link, no elements are imported into Robot
It doesn’t work to copy loads between levels
Point clouds: Number of displayed points changes as you zoom, hover or select
Region filling not transparent when printed
Revit 2015 Nvidia Desktop Manager causes dialogue boxes to appear off screen.
Revit 2016 does not use language packs
Revit Help file, tutorials, community, videos not opening
Revit Server: Clearing the cache on a Revit Accelerator
Revit Server: Slow performance with hard disk encryption
Roombook System.TypeLoad.Exception load error
Sketch lines disappear after finishing
Some columns explode on export to DWG - Revit 2015, 2016
Space does not fill area of Room in linked Revit model
Structural columns are not cutting walls in Revit
Structural columns don’t display in detail view
March 2016
“Show Previous + Demo” phase filter does not hide New Construction rooms
3D Connexion Space Navigator mouse is slow in upgraded Revit 2015 projects
3D view shows holes in floor slab where floor is joined with walls and beams
3DCLIP not displaying section correctly in viewport
Area calculation of rooms under a roof in Revit
Certain Revit elements are half-toned within a particular view
Cloud render may generate incomplete images
Color fill legend and color scheme errors: “Calculation Failed” “Color Fills calculation failed”
Creating Adobe PDF dialog gets hung up after loading R2
Crossing pipes in 3D - Revit MEP
Data deletion and retention policies with C4R
Elements of detail group move or disappear after callout bubble is rotated
Error upon pasting family that has a void revolve: “Can’t cut instance … out of its host”
Error: Revit cannot run the external application “Autodesk Seek Plugin for Revit”
Exported DWG file from Revit is not showing properly
Exported DWG file includes second set of detail lines in same position
First line drawn in drafting view always has a thin line weight
How to change Revit default Base Constraint
How to check Collaboration for Revit status
Leader lines on material tags are shifted when the model is used as a linked model
Linked IFC file is not properly aligned in Revit
Manage A360 Models Tab Not Working
Material missing from ADSK file opened in Revit
Material takeoff schedule has extra, incorrect rows for structural columns
Parts of in-place mass that are outside the view range still appear in a view
Revit 2014 cannot open files directly when using Titus
Revit By Linked View Annotation Shown Incorrectly
Revit cannot recognize Chinese Assembly Code Description
Revit displays analytical floor inverted
Revit Error: Cannot load non-shared version of Revit family
Revit Error: Last type in system family Stacked Wall cannot be deleted
Revit Extensions Freeze Drawings
Revit freeze when modifying schedule parameter
Revit freezes, cursor becomes spinning circle upon attempt to change name of material in schedule
Revit material not displayed as expected
Revit: missing Ashrae tables at several duct fittings
Section line rotates when its Drag control is moved
Space naming utility creates incorrect space names and numbers
The dwg export result and print result are incorrect
Vault/Revit server error: The directory of the destination file doesn’t exist
Wrong angle of elevation/sections after Rotate Project North
April 2016
“Two Cut - Square” rafter cut: Roof’s base is higher than specified level
Allow Slope Adjustments parameter not available by default in elbow pipe fittings
Allow Slope Adjustments parameter not available by default in pipe fittings families
Base Extension Distance changes how walls joins look graphically
Ambient Shadows do not display in 2D floor plan views
Automatically remove details from Recognize Revit feature doesn’t work flawless
Cannot select halftone elements in a Revit view
Cannot use clash pinpoint in Revit: No clash results have been shared with you
Collaboration for Revit: Operation could not be completed / Local model could not be created
Constraining position of nested door panel families
Duct lines are lost when export to DWG in Revit 2016
Custom Background Image of elevation/3D perspective view will not print
Detail items disappear from section view after Rotate Project North is used in plan view
Door Operation UNDEFINED after export of model from Revit to IFC
Error “Revit 2017 is not in run” while sending model from RSA to Revit
Error: “Enter a value or a formula starting with =” at trying to load certain families to Revit 2017
Error: “The ramp’s base (base level + base offset) must be below its top (top level + top offset)”
Export a project to IFC
Get Up to Speed: Autodesk Revit 2017
How to check Revit Server for basic functionality
How to generate site model with Grauss-Krüger coordinates
How to modify text instance properties
Hidden lines in 3D view are displayed unexpectedly
HTTP Error 500.21 - Internal Server Error when running Revit Server
IFC import \ link - geometry is not correctly imported
Inconsistent behavior of ambient shadows in Revit
Incorrect radius for W-Wide Flange-Profile.rfa
Incorrect values at spot elevation referenced to Survey Point and Project Base Point respectively
Installing Revit 2015 or 2016 on Windows 7, you get the error: You cannot install this product on th...
Lighting level calculation in Revit
Linked DWG does not display through linked Revit Model
MEP object hidden lines not showing for elements in linked models
Missing elements in Revit sheet view when printing with vector processing
Material that includes an image looks skewed or stretched when applied to imported DWG model in Revi...
Mirror command doesn’t work
Missing materials on Revit objects imported into Showcase
Operation could not be completed when syncing to Revit Server 2015: Cannot create a file when that f...
Pointclouds files are not being assembled in the same place
Print Preview does not open
Revit - Structural Analytical lines are not centered
Revit 2016 hangs every few minutes with borrowed license when disconnected from VPN
Revit cable tray fitting bend radius parameter
Revit crashes when clicking in drawing window of a floorplan
Revit DBLink export shows null values
Revit Error: Unable to load keynote data
Revit Hangs on Startup with secsplashwnd popup
Revit text wrapping
Revit: Unrecoverable error when opening any project
Revit Server Administrator is not available
Revit MEP - System Browser will not display
Revit Server Model Creation Utility: Unexpected arguments
Set IFC classes in Revit IFC export
Spot elevation symbols are missing in Revit
Stringers do not display in plain view
Tag All Not Tagged does not work with Linked Model set to Underlay
The ends of Reference Planes are pickable in Duplicated View
Unable to align non-continuous grid end points after elbow was added to gridline
Unhandled exception when attempting to select a .doc file with the Revit Extension Text Generator
Unrecoverable error occurs
Unrecoverable error opening Revit model on one system
Unused SecretInternalRadArrowhead arrowheads cannot be purged from Revit project
Wall foundation type generated automatically
Wall Joins not cleaning up in corners
May 2016
A360 Team: Viewer in web browser shows linked Revit model but not the host model
Add a Sheet
Autodesk Shared Reference Point
BOMA 2010 standards for area types/ area schemes
Bridge swept blend creation using Alignment XML as path
Can’t access individual cloud credits for rendering
Cannot save changes to Revit ini
Cannot edit elements in a Revit project
Cannot Include Revit 2017 Add-Ins to Deployment to Install Silently
Circuit and Panel information are not displaying in the Properties for Mechanical Equipment.
Core materials show through with wall base extension
Electrical circuits: Wires are drawn as if connector’s position is fixed at center of view
Elements automatically borrowed when opening a model
Family editor slows down performance
Fill region in nested family does not display in some callout views
German or English Revit 2017 shows Chinese characters in schedules
Generating tagable openings in Revit structural beams
Hidden lines override on linked elements doesn’t seem to work
How to create revision history sheet \ schedule in Revit
How to set iso \ metric bolts in Revit 2017 Steel Connections
How to Move the Project Base Point and Survey Point to the Project Startup Location
How to show relative elevation values in a Revit elevation view
Inconsistent behavior attempting to insert special characters with keyboard shortcuts
Linked model on a Revit server is missing
Loading Revisions tag
Looking to initiate multiple RVT files for C4R at the one time
Model fails to bind in Revit 20
Missing tags when batch plotting multiple selected sheets from Revit 2017
Phantom lines when rendering a material with a bump (no image)
Point Clouds continuously refresh on sheets
Purge unused deletes objects in use
Revit 2015 Add-in for APL is not working
Revit 2017 steel connections crash
Revit 2017: Reserved selection and typing direction in text editor
Revit Error: Invalid formula found in the “ParameterName” parameter
Revit Server 2017 SQLite issue after install
Revit Server: HTTP 401.2 – Unauthorized
Slow when panning and zooming in the default 3D view when set to realistic
Steel Connections don’t show in the view
Structural columns get covered by floor slabs in floor plans
Text Notes in Annotation missing on model reload
Unable to install Batch Print Add-in for Revit
Unloaded DWGs visible in underlay
Wall layer hatch missing when joining wall geometry to structural columns
June 2016
Basic printer troubleshooting
Can’t delete Sheets using Sheet List
Collaboration for Revit model shows 0 Bytes after publishing
Collaboration for Revit Error: “Publish [Model Name] latest version failed”
Collaboration for Revit: After working for a period of time, error that you don’t have access shows ...
Controlling visibility of section lines in different floor plan views
Customizing the Revit.ini file with a relative path
Glue a model from Revit 2016 to BIM 360 Glue it shows up as a bunch of dots.
Grouping elements that belong to an assembly causes assembly duplication
Hide analytical nodes of beams in Revit
How to add rabbet to a window family in Revit
How to backup Revit Server
How to change units of parameter field
How to display a top down view including the ceiling grid for printing
How to handle transparency of a family in multiple Revit views
How to import architectural columns from IFC file as structural
How to use certified families for a number of language packs for Steel Connection tool in Revit 2017...
How to use Revit Viewer Mode
IFC file not exported or contains no objects after Revit interface language change
Incorrect material schedules for wall layers in Revit 2017
Issue of group of mass
Missing Revit file format on Showcase import
Printing issue with wireframe visual style
Revit 2016 - Cannot transfer view template by transferring project standards
Revit 2016 - Etransmit doesn’t repath links completely
Revit 2017 type selector displays no matches when attempting to place structural connection componen...
Revit 2017: GBXML export option is grayed out
Revit - Default Line pattern of Reference Lines is set to blank in Object Styles
Revit steel connections 2017 do not work
Revit Model Review Add-In - Change the Result Folder location
Revit Server Administrator Error: Could not load type ‘System.ServiceModel.Activation.HttpModule’
Revit: No output with OCE plotter when using “Visible portion of current window” option without prev...
Tag All doesn’t respect selection
“Unable to obtain a network license” when saving a project
Viewports Rotation doesn’t keep the text readable
Views have detail elements disappear on sheets when panning
Where to download Roombook Areabook Buildingbook for Revit 2017
Wall layer structure changes unexpectedly
When populating the field using the dropdown in the Schedule, it does not grab all the text associat...
Azmeera M.
Autodesk Employee
Azmeera.M
ARCHIVE:
July 2016
2017: How to Complete a Clean Install and Uninstall of Revit products
Adobe Acrobat Pro DC hangs when printing from Revit 2016 or Revit 2017
Alignment lock to core wall not possible – Padlock icon doesn’t show up
Area cannot be exported to IFC when inchuling two connected areas in Revit
Batch Print Utility 2016 tries to upgrade project file
Collaboration for Revit: Corruption after successfully synchronizing model
Column doesn’t show hidden line in Medium Detail Level when overridden in VG
Cutting group instances with void in Autodesk Revit
Detail Lines shown printed with an additional line
Difference in text between tags and texts in Revit 2017
Duct disappears in 2D Wireframe in this 2017 drawing
Error - Setting incompatible with printer
Error upon copying and pasting elements: “There is a circular chain of references…”
How to include model elements from linked project in schedules
How to submit a product enhancement idea for Autodesk Revit or Revit add-ins
Inflated File Size
Learning resources for Autodesk Revit
Nested shared families do not report their level in Revit schedules
Openings in sloped flat roofs in Revit
Plan views: Stair nosings are not displayed
Released Revit 2017 Updates & Add-ins
Resources for learning about Autodesk Insight 360
Resources for learning about Revit Energy Analysis
Revit - Insulation Thickness and Insulation Type missing in tags
Revit 2017: Files are not indexed in Vault Professional 2017
Revit Annotation text shifted when mirrored and loaded into project
Revit Crash after working for a period of time (ElumTools installed)
Revit FBX Export may take long time
Revit LT - Nested linked CAD data hidden in view
Revit Server 2017: Remote Storage does not work
Revit slow performance with Dyno Browser
Revit stops responding after finishing a group
Revit Unrecoverable error after install
Revit: cannot edit places list without signing into Autodesk A360
Some elements from linked model not printed
Trim/Extend Multiple Elements in Revit cuts some lines incorrectly
Why are section head symbols always blue in Revit
August 2016
“Allow navigation during redraw” in Autodesk Revit 2017
After installing SP2 for Revit 2017, error that .NET Framework 4.6 must be installed.
Arial font doesn’t show correctly in Revit 2017
Cannot remove center line in duct fitting family
Change a parameter in all instances of a nested family
Cloud rendering colored fringe around objects when using background image
Color scheme fills of pipe elbows don’t rotate to True North in Autodesk Revit
Constraining a circle to reference lines in Autodesk Revit
Coplanar Levels causing copying confusion
Dimensions disappear in an Autodesk Revit project
English warnings in non-English Autodesk Revit products
Error: Autodesk Revit Interoperability for 3ds Max is not installed, or installed incorrectly
Hang when clicking Open after recent Dropbox update
Hatch patterns exported to DWG are displayed different from Revit
How to adjust grid symbol size in Autodesk Revit
How to edit the Handrail Bracket Support position
How to launch Revit without Add-ins
How to tag the height position of a wall opening in Autodesk Revit
How to window select over elements
Incorrect “Elevation at Top”/ “Elevation at Bottom” values at beams if z offset value set
Keynote is not working with Linked files
Lost type image when loading Revit family into project
MEP elements drag reference is aligned to Project North
Not correct printout for masking region nested into another family
Not possible to print on network plotter
Pasting family into a Revit project appends name with a 1.
Project base point after exporting Revit view from sheet
Revit 2017 with RPCs may render incorrectly in a cloud rendering
Revit 2017: How to create Room tag including Width x Depth parameters
Revit crashes when deleting structural framing element
Revit Error: “Revit could not start the print job because it was unable to connect to the specified ...
Revit Error: Roof cannot be joined
Revit Model Review does not work in C4R
Revit scene is scaled differently in 3ds Max
Revit: Make Current does not change the current site within the project
Rooms are unexpectedly exported from Revit
Shear plate connection behavior not as expected
Should I turn my computer off and on again?
Standard plotting are imperial for views in exported dwg
Unable to export render image in Revit 2017 Traditional & Simplified Chinese version
Unable to upload/view 2016 Revit RVT assemblies TO A360
Wall will be disappeared when using wall join by miter
September 2016
“Analytical model edge cannot have a length of zero (0)” message when enabling structural property o...
3ds Max file size increases when importing Revit file
After Revit launches, accessing features within product generates an error ‘Unable to obtain a netwo...
Arrow head on stair path does not show up
Autodesk Revit is very slow when moving model elements
Cannot transfer Conduit Standard type in Revit
Cloud model from Shared A360 Site link cannot open after being downloaded
Delete button doesn’t work in text editor
Detail lines and detail items do not appear in linked Revit file
Door loses reference level when copied or mirrored in Revit
Error: “The project cannot be saved because the user name you are using is not the same as the user ...
Faulty display and calculation of Room area in Revit
Grid lines are shifting when using PDF raster printing
Group behavior when a level moves in the model
How to print different page sizes or orientations in one file
How to understand behavior of Level elevation with project linked by shared coordinates.
HTTP Error 404.3 browsing SVC files in Revit Server
Importing a DWG into Revit prompts warning: “Some numerical data within the imported file was out of...
Joists are not imported from Robot to Revit
Keynote file won’t Reload in Revit 2017 with Excel open
LandXMLin fails to import file exported from Revit Site Designer
Manually install Revit or Revit LT Content Libraries
Modifying Section box changes the visibility of the model
Navisworks license error message when locally importing a Revit file into InfraWorks
No Preview Available when selecting RVT file and Windows Explorer Preview Pane turned on
Non-uniformly scaled blocks shift location
Pipe and Duct insulation at T-connections in Revit
Pipe’s center line appears in section even if the pipe is hidden
Regression Revit 2017 - Cutting 3D DWG with section results in inconsistent model display
Revit 2017: “Can’t find a solution for formulas for Type..” error message
Revit Add-ins compatibility with Windows 10
Revit crashes or hangs when changing the Graphics Display setting as Realistic
Schedules real time filtering is not working in some situations.
Software that can be used to 3D model houses and to create video walk-thrus
Temporary dimension not displayed in Revit
Third Party Updater Error Message Sun and Shadow in Revit 2016
Unable to duplicate Family type in Project Browser
Unable to run the analysis with an error “There has been an unexpected problem. Unable to Analyze…” ...
View template changes numbering on keynotes
What is the difference between Autodesk Collaboration for Revit and BIM 360 Team?
October - November 2016
“Invalid Connection Input” error in Revit when importing SMLX file with joints
“Move To” with a circuit in Electrical Panel Schedule does not work
3D content - importing and revising a large family
Autodesk Revit - rules for keeping instance parameter of walls
BIM360 button missing from Revit 2016 after updating to C4R v8
Can Revit 2012 files be saved in Revit 2014 or later?
Can’t find new content released in Revit 2017.1 update
Collaboration for Revit: How to upgrade models
Collaboration for Revit: Manage Cloud (A360) Models dialog will not load projects.
Copy and paste text elements between Revit views
Crash in Revit while using transfer project standards
Creating Elbow Angle parameter in schedules and generating it on Tags
Difference between Revit and Revit LT suites
Error opening C4R model in A360: The file is corrupt.
Error: When adding files to Autodesk Vault from Revit ‘Error occurs when updating view.’
Exporting Revit to AutoCAD without line segment
Filters and graphic overrides have no effect on Revit legends
Finishing or working in group editing generates “unrecoverable error”
Generate insight (Insight 360) returns the error «Le format de la chaîne d'entrée est incorrect »
How to include the computer name in Customer Error Reports (CERs)
How to learn more about Revit MEP capabilities
Incorrect kerning of all fonts in Revit PDF’s.
Joining monolithic stairs and floors
Layer thickness of multilayer roofs in Revit
Missing contour lines of top rails at winding stairs in elevations
Monolithic Stair Top Level
Multisegment Grid Bubble not showing on one end
PDF printing hangs up when printing Revit plan views
PNG inserted in REVIT sheets - Transparency of background not considered
Revit - wall preview missing in properties palette
Revit 2017 - Cannot print text properly
Revit 2017 - inconsistent behavior of opaque text background and zero offset border
Revit 2017 - Unrecoverable error after exiting Revit
Revit 2017 Error: Starting a new transaction is not permitted.
Revit 2017 Steel Connection Crash
Revit 2017.1: Space Naming command is grayed out
Revit 2017: Print Command not functioning after Windows 10 Anniversary Update
Revit cannot run external tool Revit2RobotConnector
Revit error - Line is too short
Revit pipe cannot be selected with Show Hidden Line tool in Coordination views
Skylights not cutting through multiple-layered roof
Text from upgraded file displays differently in Revit 2017
Text in new Revit 2017.1 project is cut off until regenerated
Text in PDFs printed from Revit 2017 is very large
The filter rule ‘Level is above’ doesn’t function in a level below
The Specified Revit folder does not exists when trying to mapping a Revit server folder to Vault Fol...
Truss changes geometry if non bearing offset parameter used
Unable to save a copy of Revit project file to Vault with the command ‘upload to Vault on synchroniz...
Users reported that Detail groups does not update when moving a Line
Users reported that duct lining does not print if duct insulation is turned off in Revit
Views and sheets are missing when opening Revit model in A360 model viewer
Windows Error “Program has stopped working” when closing a session - Event Log : Faulting module nam...
Wire tag misplaced when started to move or adjusted leg
Wrong floor quantities if floor cut by objects or voids in subsequent phase
Wrong hatch pattern on some elements exported to dwg
Wrong text color exported to dwfx using black lines settings
Wrong volume of floor layer in material takeoff when floor joined to other floor
Azmeera M.
Autodesk Employee
Azmeera.M
December 2016
Adding Revit 2017 SP2 to Revit deployment image
Autodesk Revit reports error - The publisher of this add-in could not be verified
Can’t change breaker amperage rating on Revit panel schedule
Gap in revision schedule in Revit 2017
How to add Custom Libraries to spell checking
How to control visibility of family geometry in Revit
How to use Revit data in AutoCAD Plant 3D?
Is it possible to show both duct and pipe as single line in a medium detail view
Pinned section views can be deleted from the project depending on how they’ve been selected
Revit - Pipe fitting disconnects when flipped
Revit - Structural Connections - Join/trim issue
Revit 2017 View Cube and Navigation Bar disappear after exporting DWF
Revit filled region border lines not displayed
Revit Insight 360: Users Report that lighting analysis overlaps different floors
Revit Model crashes under varying circumstances
Revit section connected to crop view looses connection upon create similar command of new section
Steel connection function still not work for China and Japan content from 2017.1 update
Structural connection stops reference planes from cutting beam and column
The view doesn’t chang the appearance when changing visual style
Unexpected borrower of elements in a Revit workset
Users report that linked DWG with shared site: “Move instance to” works unreliably between reloads.
Users report that materials applied to toposurface gets obscured when in realistic perspective view
Users Reported that printing Multiple 3D Views on a sheet causes Graphics to deteriorate
Users reported that stair geometry gets cut when the run has an angle to the landing
Where to find qrVR app
Azmeera M.
Autodesk Employee
