Actually, personal needs are not the issue at all. The issue is esoteric technical specifications that most laypeople don’t understand or are not even aware of, such as the problem I discovered (after purchasing what I thought was a perfectly suited Asus laptop) with the fact that certain Asus computers evidently force you to go through the Intel to the NVIDIA, which is apparently why I can’t properly run Autocad 2017. I’ve tried downloading the supposed fix (didn’t work); I’ve tried changing the settings to dedicate it, but evidently what Asus considers “dedicated” is not the same as Autocad; etc.
I see this question being asked a lot as well (I know, I’ve asked it myself) and it is so infuriating to have the answer always be, “Personal preference.” I spent days researching the perfect specs and spent half my rent on what should have been the perfect computer only to now own a brick as far as being able to use it for the primary reason (Autocad/Revit) and all because of something I couldn’t possibly have known was a fatal issue.
Is it really too much to ask for a software company to say: these exact make and models with these exact hardware specs are what we recommend for our incredibly expensive product to operate properly? If you like Mac, you need to buy this, this or this one. If you like PC, you need to buy this, this or this one. Done.
/vent
