@yes_and_no , @mhiserZFHXS , @ToanDN , @RobDraw , @barthbradley :
That easier way is more difficult for me . I used to do that and it was tricky to figure out whether to answer “new only” or “overwrite” for the Project info transferred from old projects, most of the times I used to make a total mess, Cntrl + Z…
Let's suppose I make 1 blank project, I create the Project information template by adding new Project parameters either like Project Parameter or from the shared parameters file, I copy this file 6 more times to get 7… I have to open 7 files to fill out Project information…
If one or two new parameters are needed to be added, like owner´s sister name + General Contractor´s mother-in-law´s cats colors (just to say something), I need to open again 7 files to add these new project parameters (most of them are not shared) or import them from the shared parameter file.
Additionally, I have to create a Master Central Model where the 7 outdated files are, that is a total of 8… and then, in order to update the Central, I need to open 7 more, transfer new project information, choose, new only or overwrite the cats colors and the sister name…
For the other hand, If I need to update my over engineered title block, to add the color of the cats and the sister name of my client, I will also need to open 8 files so that the “Overwrite the existing version” takes forever 8 times (Forever means like 5 minutes per file = 40 minutes, almost 1 hour).
From the very beginning, with just a few information in my Title block, with a decent computer, it also took forever to overwrite (30 seconds or 1 minute it's an eternity for me) …
That's why I had to over engineer my Title Block and Switch on/off information instead of create a project template to delete information that I do not need or copying again from old files.
It's easy for you because you are more experienced, I am a beginner, I only started in 2016. Parametric labels and families are really new for me, my knowledge is based on Architectural design, programming engineering it's not my field, I started back in 2019 designing my unique Title block, my Unique Paper-Model File for 7 external or internal models, now I only have to wait 4-5 minutes for my updated Title block to load… As soon as I upgrade my graphic card-RAM, things will change.
At this point, I think I will not need to open this overengineered Title block family again, it contains enough information for the kind of projects I develop.
As soon as I get my NCARB & my Architect License, big projects I will do, big dreams will be real and undoubtedly, I will hire you guys to helping me out with design, document and draft.
I am sharing with you all my crazy unique model & my Shared parameter file, to be analyzed in your lab like the most weird specimen (lol) just follow the link.
There are several ways to go to Rome, you are taking the freeways and airplanes, I am riding my horse...
regards.
https://www.dropbox.com/scl/fo/7m9qarpy7et1wwo8tgq2s/h?dl=0&rlkey=v54ufp32i3i25np1brmxb00g8
I am working on my NCARB towards my California Architect License,
if you think you can help me to complete my AXP, please let me know, I will really appreciate it. Thank you & Stay Wealthy, Happy, Healthy and Safe 🙂
Pedro Nel Ospina Hincapié
Bachelor in Architecture - Naval Architecture Student
