Keynote Schedule Drop Down List
I have a keynote schedule that has drop down lists. The problem is if I say create a keynote that says "Demolish doors" and then change it to "demolish doors, typical" It will keep both texts, and the previous one no longer applies and should go way. It can get confusing when the keynote keeps expanding and you have 4 versions to choose from.
Is there a way to make it so any unused text disappears?
Thank you.
SteveKStafford
Your description suggests to me that your keynote schedule isn't using the keynote tools or legend. It sounds like it is the schedule keynote workaround where it is a Schedule Key based on an element category, ideally it is based on one you are not using in your model. If that's true the list will usually eliminate any values from the drop down list once there are no instances of it anymore. Is it possible there is another instance of that description being used elsewhere that you haven't noticed?
Steve Stafford
