Keynote Not Showing in Schedule After Printing
mspainHEBJ5
mspainHEBJ5
When originally placing the keynotes in the plan on this sheet, they all scheduled in the Referenced Keyed Notes schedule properly. However, after printing, one specific keynote no longer shows in the schedule. It still appears on plan, and after opening the schedule, the information is still there. There are no filters applied to the schedule besides checking the box to filter by sheet. Removing and placing the keynote again makes it show.
Does anyone know why this is happening. It is also happening in every project that the keynote is used in.
syman2000
Did you try reassign the keynote value and see if the keynote will stick?
mspainHEBJ5
Yes. That helps it stick the second time around, but it has not stopped it from happening on other projects. So, it fixes one instance, but not the entire issue.
