Muntin Family Not Displaying Correctly
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
ZDCMapp
205 Aufrufe, 2 Antworten
Having an issue bringing a muntin family into a curtain wall door family I'm working on. I used a door grill family from one of the stock doors and modified it. However, when I bring it into my door family the vertical muntin is not loading. To test it I loaded the stock door grill and it looks fine. Don't know what I'm missing here. Be sure to scroll down to the end. It's a long winded post. Sorry.
Original grill
My grill
Horizontal muntins are only showing for some reason.
Also, when I bring into my model, the only thing that is showing is the model lines. The grill is not visible like in the original door model. Don't know if it is a curtain wall door vs. standard door family type of thing.
My model
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: ZDCMapp
The muntin was assigned to a visibility parameter.  Remove the association and make it Visible.
Nachricht 3 von 3
ZDCMapp
als Antwort auf: ToanDN
Sorry for the late reply but you are correct once again. Thanks!
