Keyboard Shortcut
Keyboard Shortcut
elias.larsson
Message 1 of 9
Keyboard Shortcut
elias.larsson
No popup only greying out of the screen and warningsounds when i press the workwindow when i press (ks) or enter the meny any other way.
Anyone know whats wrong?
Replies (8)
Message 2 of 9
_Vijay
Alternatively you can customize from here..
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 9
georgehobel
is it possible that you are in the middle of some other task?  my first thought would be to hit escape like 16 times... then try "ks"
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 4 of 9
elias.larsson
Same issue in all paths to the option.
It seems like i get the poput somewhere but i cant see it.
Message 5 of 9
_Vijay
can you share image something?
Vijayakumar
Head of BIM
Message 6 of 9
Are you working on a dual monitor setup -- or recently disconnected from one?
Message 7 of 9
Mohamed-Nassar
I Faced this problem before take care,
1- Try to check this version of Revit is haven't any problems
2- try to close revit if this problem is Appeared and reopen it again immediatly to check this happen while you are working
3- Check the Path of the Keyboard shortcut File to see if it places with the right name and in his place or try to replace a new Keyboard short cut
This Link will help you with this
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Best Regards,,
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 8 of 9
elias.larsson
It did not help to restart revit.
But after i restarted the computor it worked.
Perhaps it har something to do with the dual monitors?
Message 9 of 9
Did you have dual monitors set up at one time?  You never said.  But, if you did, reconnect the second monitor, type KS and see if the dialog box pops up on the second monitor.  If it does, drag it over to the Primary Monitor.
