Keyboard ShortCut Issue in Revit 2023
baeksm
baeksm
Except Revit 2023 version, I used to use Keyboard Shortcuts at Revit home(Attached photo below), for example ctrl+N (Create New Project), ctrl+O (Open Project) etc.
But Keyboard Shortcuts are not available at revit home in Revit 2023 version, and I couldn't find any change about Keyboard Shortcuts in What's New in Revit 2023. Is there anybody who know this issue or can solve?
MichaelDol
The same problem, I think it's a problem on the developers' side.
Mikhail Dolgikh / Михаил Долгих
BIM-Manager & Teacher / БИМ-Менеджер - Учитель
Facebook
jwarga9ZMAP
not sure if this has been answered, I was having the same problem.
Solution for me:
File > options > User Interface > Keyboard Shortcuts > Customize > In the search, type in "VISIBILITY" when visibility graphics shows itself, and insert "vv" into the shortcut.
jay_colcombe
I have an issue where I did not have any Shortcuts via a deployment install and though it might be related to that.
Fortunately I have Revit 2021 installed and exported the .txt file from this version and imported into 2023.
I will now save it locally and path it here for every new install as I do with dictionaries as I am constantly adding to them and they get reset with every new install
Jay Colcombe
Autodesk Certified Instructor
baeksm
I know how to change shortcut but it doesn't work in Revit home. Thank you for your replying. Cheers!
baeksm
I exported Revit 2021 Keyboard Shortcut File and imported it at Revit 2023, but it also doesn't work in Revit home. Thank you for your replying. Cheers!
baeksm
Yeah, I think Revit 2023 home has difference with the other version Revit home. Only in Revit 2023 home, I couldn't use Keyboard Shortcut properly. Thank you for your replying. Cheers!
