Key Parameter does not change Family Type Instance parameter value
esatis
Message 1 of 10
esatis
I have door Family with door handles that are assigned to Shared Family Type Instance Label DOOR_HANDLE_INSIDE - the door handle Family Types can be changed from Door Instance parameter. This Shared Parameter is added to Key Schedule along with other Parameters, but for some reason the Key parameter does not change the value of the DOOR_HANDLE_INSIDE. It does change other Text Parameters for that Door, but the DOOR_HANDLE_INSIDE is set and `grayed out` and is not driven by Key Parameter.
What could be the issue here?
The door in question is added as Family Type Parameter to Curtain Wall Panel:
[Curtain Wall Panel]->[Door]->[Door Handle]
Replies (9)
Message 2 of 10
mhiserZFHXS
If the parameter is grayed out, that would suggest that it is being controlled by the key.
Can you be more specific about what's not being controlled? Is the text for the family type parameter changing but the actual model is not changing? Or is nothing changing?
Message 3 of 10
Can you post the actual file so we can follow along?
Message 4 of 10
Do you mean it is greyed out in the Key Schedule?  Can you share a screenshot of the key schedule?
Message 5 of 10
TripleM-Dev.net
Hi @esatis ,
I think it's easier to check if you share the family, or better a project file with the Curtainpanel > Door > door handle.
Quote:
"I have door Family with door handles that are assigned to Shared Family Type Instance Label DOOR_HANDLE_INSIDE - the door handle Family Types can be changed from Door Instance parameter"
In the description of the post, you state parameter "DOOR_HANDLE_INSIDE", but in the second part of it it says "the door handle Family Types can be changed from Door Instance parameter" this is the same "DOOR_HANDLE_INSIDE" otherwise I see something off.
I've tried the setup with a "Family Type" label selector (Shared + instance), and this works. Haven't tried the nesting inside a curtainpanel, but I assume the door itself is a shared family, else you couldn't edit a keyschedule item for it.
Message 6 of 10
esatis
for that family i have Text Type Parameters and Family Type Parameters (labels, where I can choose which nested family to display).
Text Type parameters are changed by key no problem, but the Family Type Parameters are not changed by the key. When I place the door outside of the Curtain panel, everything works. So I guess this is a bug that locks the Family Type Parameters. Because they are grayed out when I have placed the door in curtain panel, but not assigned any key.
Message 7 of 10
esatis
Sorry, no , this Family is covered by NDA
Message 8 of 10
esatis
Hi, no it is not grayed out in Key Schedule, I can change it in Key Schedule.
Message 9 of 10
esatis
Hi, thank you, but i think that the bug itself is specially in the nesting in curtain panel part, because when I place the door outside of the curtain panel, it works as expected- key does change the Family Type label selector parameters.
Message 10 of 10
esatis
Basically what I figured is that for Nested Family instance, in may case Door: [Curtain Wall Panel]->[Door]->[Door Handle], I can change only Text Type, and Image Type parameters. The Length Type and <Family Type> parameters are grayed out and I cannot change them manually selecting nested instance or drive them through Key Schedule. Thats a bummer..
I could associate the Door instance length parameter to Curtain Panels instance parameter, then drive that from Curtain Panel Key Schedule, but I cannot associate Door <Family Type> Instance Parameter. There is no Associate button. See the screenshot below of Curtain Panel family in Edit mode (door are selected).
