Keeping assembly Views Aligned With Assemblies
Hugh_Compton
Advisor Advisor
Hugh_Compton
I might be missing something obvious but is there a way to keep assembly views aligned with assemblies when the assemblies are moved / rotated etc in the project?
When I move my assemblies the views no longer align.
www.TechRoom.bg
This is very unclear description of problem.
General view and assembly are easy fix problems if someone can understand your problem correct.
Can you try to explain issue more detailed or attack some screens ?
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Hugh_Compton
I've attached an image to further illustrate the query.
www.TechRoom.bg
I try this on my project.
When you create you assembly i try with 3D ortogonal.
Go to lock view and than place tags, dimensions and etc.
Here is lockation of lock view button
And heres my test results
dimmension is there in both cases. On same place just i moved it.
I hope this will help you!
Eng. Iliev L.
Hugh_Compton
Hi
Thanks for looking into this.
If you now try moving your assembly by, say, 10 metres/feet then would your locked assembly view still display your assembly? On mine the assembly view disappears...
