Keep default copy/non copy consistent when mirroring
Olga_vlagkouli7TWTA
Observer Observer
Olga_vlagkouli7TWTA
Observer
Observer
Hi, is there a way to keep the default copy/non copy consistent during mirroring? This has been consistent for numerous version of REVIT but on REVIT 2023 I need to keep remembering to check if it is ticked or unticked. Is there a way to maintain the default always the same as it used to be?
RobDraw
I haven't used 2023 in a project but the initial setting from opening a project is copy. Once you change it, Revit will remember your last choice until you close and reopen and then go back to the default.
Are you seeing something different?
Rob
