jpeg files
jpeg files
jpeg files
hello the community
how do i get to print my revit level plans into pictures so as to import them into word
thanks
dzanta
Revit printing looks at the available printers you have within Windows OS.
If you have a printer that you can set to print to JPEG or other raster based files, then Revit can print to JPEG.
I do not have a printer as such.  I will usually print to PDF and then use Bluebeam Revu to batch print the PDF files to JPEG format.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
loboarch
Would a screen capture work? That might be the easiest.
You can export a Revit view directly to an image file though using the export function on the Application menu.
Once there you can set the requirements/setting for the image export.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
FGPerraudin
Hi @Anonymous,
Just export your presentation in jpeg instead of printing it!
Main Revit menu > Export > Images
Should solve your issue!
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
