Joining Curve Walls
Joining Curve Walls
Message 1 of 8
Joining Curve Walls
Hello, I am an architecture student working on this building and I was trying to see if there is a way to join this curve wall together. I have tried the arc functions but I was not able to achieve the curve I wanted. Listed below is an example of the curves I am dealing withto achieve this curve I had to split up th walls and I want it to be all just 1 wallto achieve this curve I had to split up th walls and I want it to be all just 1 wall2.JPG
Replies (7)
Message 2 of 8
Join it how?  I mean, it looks joined to me. Edges look contiguous.
...Join Geometry (Modify Tab) not working for you?
Message 3 of 8
You can create a Mass from / surface from a continuous spline and then create Wall by Face.
Message 4 of 8
How/Where do you go to do that?
Message 5 of 8
...Make sure Join Status is set to "Allow" on the Options Bar.
Message 6 of 8
Yes, just like that. How do you do that? By any chance can you show a video?
Message 7 of 8
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Worth noting that there is nothing wrong with multiple curved wall segments, as long as they tangent smoothly then you will see no joint lines in 3d or elevations.
Message 8 of 8
Is Join Status set to Allow?
