Family Ceiling View
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
DanielleV-4te
1063 Aufrufe, 5 Antworten
Family Ceiling View
I have created a Kitchen Millwork family with both uppers and lower cabinets. When I look at my floor plan my uppers don't show (which is fine) but when open the Ceiling plan it is blank. The only way I can see the upper cabinets is if I look at then in elevation.
I can't see a way to adjust the view range for a family.
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: DanielleV-4te
Is it a Casework Family?
It's the Geometry within the View Range? Is it Cut in the View Range?  Is the Geometry's Visibility Setting set so that the Geometry is Visible in Plan/RCP?
Hey, we could good on and on. There's at least 33 questions I could throw at you. Post your file here. That will make it faster and easier to troubleshoot.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 3 von 6
martijn_pater
You can. Just select the view in project browser and edit view range for the view properties.
Nachricht 4 von 6
DanielleV-4te
als Antwort auf: barthbradley
To answer the first question, it was created in a generic family template.
2) I cant locate the areas where i can adjust the view range in the family editor file.
I attached the file for you to look at.
Nachricht 5 von 6
They're visible here.
Ceiling Plan View:
FWIW: the Category is Casework.  Not Generic. The distinction is important. You'll understand why by reading the Link I provided about View Range.
One more thing. If View Range isn't under View Properties, press the View Name a second time to activate all it's Properties.
Nachricht 6 von 6
DanielleV-4te
having a major *facepalm* moment. Thank you.
